Home > Technical (L322) > Humppff: What's wrong ??! |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I've just had the same thing with my Cylinder Fuel readings, a couple read normal at +/- 1 and the others are at +655!! The motor idles smoothly and runs fine, no adverse change in fuel economy.
9th Apr 2018 9:06pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 146 |
Bad for you and glad form me that I'm not the only one. Motor runs fine as well (idle and when driving), fuel economy seems to be a bit low (22MPG short trips). Discotiger where you able to trace it down and fix it? |
10th Apr 2018 6:07am |
or someone else who found a remdie |
10th Apr 2018 6:08am |
Not really worried about the readings as had the motor serviced last Friday and the mechanic said everything was running fine.
10th Apr 2018 6:40pm |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
No remedy just much the same readings. I put it down to eithher over fueling at idle or the other ones too shut at idle? |
10th Apr 2018 7:04pm |
As far as I know the two are not too shut: the readings should be between -2 and +2. Anything above is no good. And I thnink overfuelling in the range of my readings can't be any good if true at least when more fuel is injected (dilution of the oil in cylinders). But this I can't verify.. Is there someone who can comment on my thoughts? If someone has the same problem please let me know, want to understand what is going on and how it can be fixed |
10th Apr 2018 8:25pm |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
those 655 readings i have those also, have asked before on forums and no one could interpret them for me. asked a diesel place and told nothing to worry about . it jumps from cyl to cyl. |
11th Apr 2018 8:09am |
