Home > Technical (L322) > Intermittent ABS / HDC /Air Susp Bongs.
Dolphinboy
Paul, is the ABS wire-in connector dry? I only ask because it is fitted upside down adn collects water which then sits adn corrodes the contacts. When Mine had all your symptoms I disconnected the ABS unit, cleaned the little bits of Green gunk on the pins, dried it and made sure it was as water-tight as poss- never had a problem again.
The only thing I can think of is the wiring loom with a nick in it and only shorts out when it moves against something metallic?
Post #474357 30th Mar 2018 3:06pm
PaulTyrer
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
Thanks, I did have a look at that and it seemed all ok, but if it ever stops raining I'll have another look!
Post #474360 30th Mar 2018 3:23pm
Matt Pearce
United Kingdom 2003 Range Rover HSE Td6 Oslo Blue
Hey Paul, i dont know if you are still around , i have only just received this notification via email..
please let me know how its all going.. many months later i have managed to sort my RR but not before a lot of chat from the dealership
Post #474361 30th Mar 2018 3:25pm
PaulTyrer
H,
Yes still around! Still getting the intermittent bongs! What the main problem is that we need the car almost daily, and to send off the unit to BBA Reman to be checked out means taking all the hydraulic pipes off, and if that isn't the issue then its money and time down the drain.
Did you get a fix with your problem?
Post #474417 31st Mar 2018 1:41pm
As previously mentioned, you need to check your ABS sensors, reluctor rings, and wiring/connectors first .
Post #474418 31st Mar 2018 2:16pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
You only send the module to be looked at NOT the hydraulic part, so no pipes have to be disconnected. From memory its just 4 screws and then you carefully pull the module away from the hydraulic unit. I swapped mine over for a good used unit and it solved my problems. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #474443 31st Mar 2018 4:47pm
Matt Pearce
Paul, Simon is right, its onlt six torx screws, but best to first remove the few bits directly in front of it before you try.. all in all its @bout 10 minutes, being careful not to drop the two right hand side lower torx into the abbys!
i actually have a good tried unit which you would be welcome to try , the only problem is that be ause one of th3 pins was corroded i replaced one with a little wire link which you solice into the wiring loom once youve got the unit in place .. very easy , but completely understand if you ar3 not keen..
i could post it to you.. and once tried you can post b@ck..
i have solved my 3 amigo lights, basically i changed the two front speed sensors ( even though they were reading ok..
was a bit of a pain changing the first because they are always really jammed in.. but once i got the hand drill out and carefully drilled right through with a 1/4 drill .. i learned the procedure..
i still have the crazy volts reading on the left front height sensor, which i f3lt sure was the oroblem.. but no-one could give me a reason for this .. so i just had to ignore it and it worked.. its bloody magic not to have th3 lights.. although having now said this it may well come back.. that the ways things seem to work for me... but in the meantime Bliss!!!
I actually replaced ABS solenoid unit ( the one you need to change ) a couple of times, first of all i removed mine cut the back off a thought id have @ go resoldering.. which i am fairly good at but got in a bit of a mess so scrapped this unit and purchased another on ebay second hand , but ironically once 8 got this b@ck i noticed that it had once of the little pins corroded through .. hence the little mod i did.. but then realising that if i ever had to take mine to a garage , and that looked
most likely i then order another . leaving me with a spare..
but in my case the abs was not the fault. of course..
but i know quite a bit more about these little Censored now!
Post #474446 31st Mar 2018 5:33pm
PaulTyrer
Matt,
Only just read your post! Don't know how, but I checked on the the DVLA web site today and IT PASSED THE MOT Bow down Bow down Bow down
Anyway, gives me more time now to have a good look at the ABS ECU and connections to see if I can find what the problem is. I'll let you know about the try-out of your unit, and soldering is not a problem.
Thanks!!
Post #475689 13th Apr 2018 11:47am
Danwilderspin
Re: Range rover l322 high volts on FRont Left Sensor. 3 ami
Matt Pearce wrote:
Hey Paul, I have had
I want to hate you for face lifting the ff and keeping the original smallest wheels with the fattest tyres on it should look stupid but it actually looks really good... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #476893 27th Apr 2018 8:58am
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Any joy at fixing this issue?
HAs anyone successfully coded a second hand one to their car? if so how please?
Post #489416 20th Sep 2018 2:18pm
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
PaulTyrer wrote:
H,
Just take module off,, no pipes, get it checked , can still run car in default mode.
Post #489430 20th Sep 2018 7:19pm
alfapat
Have a look at what goes down on my thread , D Day tomorrow with new Genuine sensors , but check the ste of tour abs rings first , every thing shuts down due to bad input with wheel speed sensors or rings , depending on how corroded they are.
Post #489432 20th Sep 2018 7:24pm
UK Marine
I have. I fitted one about two years ago.
I used P.A.Soft 1.4 to code the secondhand module to my car, basically changing the stored VIN in the module to mine. The most important thing to do is to calibrate the steering angle sensor afterwards as it stores the information about where the wheels are pointing so that the ABS module can enable HDC.
Thumbs Up ______________________________
Simon
Post #489448 21st Sep 2018 7:19am
