Home > Technical (L322) > 6hp26 shift issues 3.6TDV8 |
elandri Member Since: 28 Apr 2015 Location: Norwich Posts: 43 |
Two issues:
21st Mar 2018 8:18pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1688 |
Your gearbox was trying to tell you it had an issue when it began to judder
21st Mar 2018 8:32pm |
Mikey, have you ever thought of becoming a doctor? Your bedside manner is impeccable:)
2nd Apr 2018 8:31pm |
unsolicited Member Since: 30 May 2016 Location: London Posts: 122 |
If manual works (at higher pressure), then it may point toward solenoids or even the bridge seal I guess. You will be changing the bridge seal if the mechatronic comes off anyway I hope.
3rd Apr 2018 6:50pm |
Hi, I don't have an IID tool but I do have a mate with a garage so will try to get it there soon and see what's in there.
11th Apr 2018 6:28pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I had similar ish problems. The cheapest option I would try now if I were you would be a gearbox firmware update using the iid tool. Worth a shot for how much it costs. I'd also check the fluid level is correct. Then check the right fluid was used when you had it serviced. Start with the simple cheap things before going straight for the £2.5k option. |
11th Apr 2018 9:18pm |
Wizz991 Member Since: 23 Sep 2017 Location: North Devon Posts: 7 |
If you have had incorrect ratio faults I'm afraid the gearbox is knackered I wouldn't waste any money on trying anything else put it towards a recon box |
13th Apr 2018 11:43am |
Wiz,
13th Apr 2018 12:32pm |
Only the ones I've seen with ratio faults have required rebuilds |
13th Apr 2018 12:35pm |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 385 |
I would say it looking like the mechatronic unit, from experiencing the same symptoms.
13th Apr 2018 3:30pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 910 |
The purpose of the foam strip is to cover the exposed solenoid contacts to prevent any metallic particles in the fluid from shorting them out. To be honest, if you have metallic debris floating around in the fluid then this is probably the least of your problems.
The bridge seal (and Land Rover part number) is shown in this post : http://www.fullfatrr.com/forum/post183123.html#183123 Phil |
13th Apr 2018 4:00pm |
Many thanks Phil,
13th Apr 2018 4:40pm |
Only place I know for the firmware is IID, but there must be others. |
14th Apr 2018 9:11am |
Hi Phil, thanks for your info re part numbers. The (7) new solenoids, seals, foam strip & connector shroud were installed on Tuesday along with 7 litres of liquid gold .
4th May 2018 12:56pm |
