Home > Technical (L322) > Restricted Performance |
Defender Dave. Member Since: 01 Mar 2018 Location: Co.Tyrone Posts: 51 |
Thanks Craig - I will get this done when they do the forced regeneration. |
3rd Apr 2018 8:58pm |
Set off to my local independent to have a forced regeneration done on the DPF. Had not got a mile down the road when it went to a red warning and into restricted performance mode. At the garage the lads hooked up the computer and away they went.
15th Apr 2018 12:20pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Unfortunately the DPF issues are probably down to the previous owner doing too many short journeys. Not really the fault of the car.
15th Apr 2018 8:27pm |
I think you are right about the previous owner. Had an issue on the way home from collecting the vehicle - said suspension fault but turned out to be a frozen sensor. Hopefully we will be back on the road soon. I have more work in the pipeline down your way - must keep an eye out! |
16th Apr 2018 12:10pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
The previous member who changed his DPF reported that you have to cut the pipe and use sleeves and clamps to insert the new DPF. ( ie you don’t replace the cat etc or silencers. I think the system is made from stainless steel.
16th Apr 2018 12:42pm |
Mike,
17th Apr 2018 10:11am |
So a few days ago I got the vehicle back from my local independent. The dpf had been cleaned by a company in England who returned it with a printout of things like backpressure before and after cleaning etc. Fitted to vehicle and good to go. Over the course of the next 3-4 days I covered about 100 miles - there were a lot of short, local journeys involved - just about to head up to Donegal for the weekend and I get DPF Full - See Handbook. The last time it happened I tried the 20 minutes at 50mph plus a couple of times but to no avail. I then setoff to go to my local independent for a forced regeneration, got about a mile down the road and I got the red dpf warning and limp home mode. They were unable to do a forced regeneration and the dpf was sent to England for cleaning. I don't want a repeat of that. Should I try a regeneration but do it with Command Shift to keep the revs up? Anybody else out there get a dpf full warning after such a short number of miles? Is it just me not used to the vehicle? Help please!! |
6th May 2018 5:33pm |
Greg.
6th May 2018 8:02pm |
