Home > In Car Electronics (L322) > AV/SAT NAV/SCREEN all dead |
Closerthanmost Member Since: 27 Aug 2017 Location: Cambridgeshire Posts: 62 |
Driving along listening to the radio and as I went round a corner I thought I hit the mode button on the steering wheel and the screen displayed that the AV was off, then the screen went blank and now I get nothing.
19th Apr 2018 8:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34910 |
if you hit the red cross and the screen goes blank...when you start up next time it should be back to normal.. ... - .- -.
19th Apr 2018 9:34pm |
It's not that - it literally just closed down.
19th Apr 2018 10:54pm |
fuse? ... - .- -.
20th Apr 2018 9:42am |
Well, I pulled all the AV/Infotainment related fuses and they were all fine.
20th Apr 2018 4:23pm |
sometimes in these situations doing a battery reset helps re-boot the ecu’s so your fuse ‘in-out’ probably did the same ... - .- -.
20th Apr 2018 4:28pm |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 |
Is the system the same sort of fibre optic setup found in BWW era 322's? If so, one of the modules going bad will take down the whole system RR History
20th Apr 2018 6:21pm |
Shaun Member Since: 02 Jul 2010 Location: Hull Posts: 58 |
Water in the bluetooth / phone module? |
3rd May 2018 12:15pm |
