Home > In Car Electronics (L322) > Dashcam installation |
Squirrel Member Since: 15 May 2012 Location: Reading Posts: 201 |
Hiya,
21st Apr 2018 6:34am |
Thanks! That sounds interesting. Is your cam mounted centrally?
23rd Apr 2018 5:10pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
this one is stuck on the front window but it shows its quite flat so 'the dog' is less likely to knock it off,
23rd Apr 2018 5:16pm |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
I will sort a couple out. Mine is central at the back, the wire comes down unfortunately and is a bit unsightly, but will figure something out for that when i get chance. If feeds all the way along to the front camera around the windows and lining so nothing is seen. The power is then feed from the front to the fuse box using a feed through fuse on the lighter fuse. |
23rd Apr 2018 5:48pm |
Thanks both! I've got to try and work out which corner is going to be safer - I'm guessing offside because I approach the car from the nearside and that's where the dog bounces to. I was thinking of taking the cam out of the car unless it's in use, but then there's no point in me having it hardwired and backed up with a battery...
23rd Apr 2018 8:00pm |
