Home > LPG > Lpg injector cleaner
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Hi anyone got a recommendation for lpg injector cleaner and where to buy ?
Post #475379 10th Apr 2018 5:59pm
Aaron HSE
2002 Range Rover HSE 4.4 V8 Bonatti Grey
I have used ic12 in the past. It cleans and lubricates the injectors, you have to put it down the fuel lines coming from the filter to each bank whilst the engine is warm. Comes with instructions anyway. https://rover.ebay.com/rover/0/0/0?mpre=ht...3090815568
Post #475874 15th Apr 2018 7:55am
rik
Cheers Aaron got some ordered will use next week
Post #475881 15th Apr 2018 9:24am
rik
Ok used ic12 last night ran a bit rough for a minute eml flashing .Then went out running sweet as now .Time will tell . Anyone know what ic12 is ? Exhaust smells like aviation fuel or parafin.☺️
Post #476316 20th Apr 2018 12:19pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi Ric. would like to use that stuff as prevention, can you please tell me where you put it in? It sais "pour the fluid in the low pressure LPG line"
Me non tech, haven't got a clue...is that the line with the filter on it? Thanks in advance
regrads
Robert
Post #476477 22nd Apr 2018 5:19pm
rik
Hi Robert basically injectors side of filters I held mine up after putting 25mm in each pipe to prevent fluid running back I to filter .Do this twice to each line make sure clamps are tight and you should be good .My rml light went out instantly but is back on car running well so not unduly worried about it .Has been on and off for 6 years so not too worried good luck
Post #476480 22nd Apr 2018 5:49pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
