Home > Maintenance & Mods (L322) > 2002 petrol v8
M17tph
England 2006 Range Rover Vogue SE Td6 Buckingham Blue
2002 petrol v8
Hi all
Can anybody advise the best engine oil and spec for my 2002 4.4 BMW v8 petrol l322
Thanks in advance
Post #476594 23rd Apr 2018 9:10pm
b348xyx
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
0w40 Is what i have always used. but is alot more expensive.
anything that can get oil to the vanos units as quick as possible on startup is a good thing.
 2003 Range Rover 4.4 Litre V8 - Adriatic blue
2003 Range Rover 4.4 Litre V8 -Maintenance History Click Here = http://www.fullfatrr.com/forum/topic39687.html
Post #476614 23rd Apr 2018 11:22pm
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
Google "Opie Oils" and put your Reg No in - they give a good selection. Put Magnatec in mine.
Post #476616 24th Apr 2018 12:23am
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I guess it depends on where you live, e.g., temperature range.
The workshop manual doesn't recommend anything lower than 5W for temps down to -30 deg C.
I use Penrite HPR5 5W-40 full synthetic (oil is cheaper than an engine rebuild) but my ambient temps might be warmer than yours (it's autumn and will hit a comfortable 28 deg C today and it rarely gets below 1 deg C mid-winter). Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #476617 24th Apr 2018 3:03am
M17tph
Thanks for the reply
Opie oil site is top info
Post #476626 24th Apr 2018 9:03am
vogue16
France
hi
the zero grade is perfect for low temperture start, but i would prefer 30 for high temperature viscosity..
if you want to have a very fluid oil at cold t° or high 40 is not the best..
go for a 0w30 if you want 0, or a 5w30 Thumbs Up Current: L322 TDV8 4.4
Post #476629 24th Apr 2018 10:01am
M17tph
Thanks for the replys
My engine has done 153000 miles would a different grade be beneficial other than what's been recommended
Thanks
Post #478980 20th May 2018 7:02pm
b348xyx
Its all up to you Smile Personally i use the 0w-40 as said above... 0w Fast to vanos units when cold and as the engine runs hotter then most cars i like to have the 40 when hot.
but any the below will be fine... depends on how much you want to spend on oil.. i always change between 7-8k
    5w-40
    0w40
    5-30
    0-30
Post #478981 20th May 2018 7:22pm
