Home > Technical (L322) > Oil in intake system causing catastrophic engine failure |
Crystal Member Since: 29 Apr 2018 Location: Wincanton Posts: 3 |
I understand that there is a JLR modification (Technical Bulletin LTB000513 dated 15th January 2013) for 2012 TDV8 4.4 diesel engines as the oil drain pipe from the top of the engine is not effective such that engine oil builds up in the top of the engine and gets into the intake system.
29th Apr 2018 2:20pm |
Surprised at your reply as we thought this was a common problem and certainly replacement engines have been fitted when this modification has not been carried out, but the engine has failed.
29th Apr 2018 4:06pm |
Apologies, have just managed to find the post on this forum containing said bulletin, [http://www.fullfatrr.com/forum/post252590.html] scroll down to the fourth post from the top and it is shown here |
29th Apr 2018 4:11pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Extra background info helps. Strongly suggest you edit the topic title to include "4.4TDV8".
29th Apr 2018 4:13pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Link to the technical bulletin that works,
29th Apr 2018 4:29pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34908 |
the tsb is in the wiki as well...
29th Apr 2018 4:38pm |
Ah ok so it is the turbo drain... Well that is very common and probably every 4.4 since 2010 release until maybe the 405 (2013) can suffer from this. But I didn't know it could lead to a catastrophic failure?
How long have you had the car? . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
29th Apr 2018 4:52pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Even my main dealer used the words, “it’s pretty bad”, referring to the amount of smoke it blew out on the test run we did to confirm it needed the turbo drain mod, but never at any stage did the service manager mention catastrophic failures.
29th Apr 2018 6:04pm |
counter of beans Member Since: 18 Aug 2017 Location: Hampshire Posts: 182 |
Hello Crystal; I'm puzzled by some of your comments such as "the owners we have talked to have been silenced by JLR", and "workshop mechanics are worried about their job security" - you make it sound like it's the CIA or something!
29th Apr 2018 9:18pm |
Speaking about throwing rods, this made me remember I threw one once...
29th Apr 2018 10:39pm |
c.o.b has made some interesting points, who are 'we' and where did you get your info from crystal... ... - .- -.
30th Apr 2018 8:16am |
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 120 |
The only way I can see that dieseling can occur with oil in the plastic inlet manifold is by a failure of a turbo oil seal on the inlet side of the turbine shaft allowing oil into the pressurised inlet air side via the intercooler.
30th Apr 2018 9:54am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2301 |
The modified turbo drain is to prevent oil accumulation in the secondary turbo's inlet tract that was accumulating due to seeping through the turbo's seals from the original drain that required the engine to be running to drain via a scavenger pump, yet oil pressure persisted for a while after the engine stopped. |
30th Apr 2018 10:41am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
Thanks for giving me a good laugh 😂
1st May 2018 6:35am |
