Home > Technical (L322) > 3.6 tdv8 car died, turbos?... confirmed engine is dead.
Keith A
United Kingdom 2009 Range Rover Vogue SE TDV8 Buckingham Blue
Was towing (approx 1.8 tonne load) and went to overtake yesterday put my foot down and it sounded like something broke and a dull grinding/clunking noise was apparent, it wasn't high pitched. First thought was gearbox, but then it was apparent that there was no power, engine warning message came on. Managed to cost off the A34 thankfully, and then when slower the engine stalled/died. Won't start now, turns over, fires, runs for about 2 seconds then dies.
Showed air mass meter errors (P010C and P010F), intercooler temp sensor signal fault (P007F) AA chap cleared these and they haven't returned but the car still won't run.
This sound like a double turbo issue? And if that what would have caused it (oil pump?).
I'm waiting for Woody from the Disco3 forum to come and collect it and try and fix it, but any idea what could cause the above. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Mini Cooper Race Car Smile
Post #480544 10th Jun 2018 12:20am
Keith A
Video of it happening. You'll need to turn your volume up.
Happens as I pull out... so about 30-35s in.
?t=25s
Car now on it's way to Woody's.
IMG_0680 by Keith Attwood, on Flickr Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #480621 10th Jun 2018 6:58pm
At least the FFRR knew there was a junction coming up! Thumbs Up .
Post #480628 10th Jun 2018 7:58pm
Paul thornton
It may have ate it's EGR valves...
Post #480632 10th Jun 2018 8:08pm
Trantorman
United Kingdom 2017 Range Rover Vogue SE SDV8 Aleutian Silver
Sadly sound expensive, if you need 3.6 tdv8 engine parts I have 3 units here for rebuild, at least your in good hands with Woody he knows what he is doing unlike the Muppets I used hence why I have a selection of previously rebuilt engines... Big Cry
Post #480681 11th Jun 2018 2:02pm
rar110
I could be intercooler/turbo hoses. ______________________________
Post #480800 12th Jun 2018 10:39pm
Keith A
Love it if it was. But sadly all new in the last year and never had the car not being able to be started when a hose has split. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #480803 12th Jun 2018 11:34pm
Keith A
Not looking good this.
One turbo is definitely gone, 2ltrs of oil was appently in the bottom hose along with most of the turbo, with some metal in the top hose. More concerning though is that engine still won't start at the moment. Woody's not sure if the turbo going has taken that half of the engine with it. It turns over fine it would seem without any undue noise.
Slightly stuck of what to do next with it. A recon engine and turbos are probably not really economically viable for a 58reg car with 120k on the clock as this would be the best part of £10k at least wouldn't it?
Any ideas/thoughts greatly appreciated. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #481557 21st Jun 2018 5:08pm
Keith A
Well.. it's dead and will be sold for breaking.
Suffice to say I'm not happy and won't be buying another. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #482554 3rd Jul 2018 11:17pm
Paul thornton
Is it not worth considering trying to find a second hand engine?
Post #482556 3rd Jul 2018 11:48pm
Keith A
Don't think so.
Car value is £9-10k.
Scrap engine approx £4k
2x new turbos £2k
Intercooler £300
All +fitting... so maybe £1500
There will be probably more little bits needed as well.
Scrap value is £3k.
From my basic calculations it just doesn't add up. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #482558 3rd Jul 2018 11:53pm
Paul thornton
Didn't realise a 3.6 out of a breaker went for so much money.
I presumed you would have been able to get an engine with turbos etc for less than 4k.
Was it the EGR valves which caused the turbos to disintegrate?
Post #482560 4th Jul 2018 12:06am
Keith A
Don't believe so. Been told they seemed to be working fine. Current cars:
09MY TDV8 Vogue SE
Mini R56 Cooper S
Post #482574 4th Jul 2018 7:48am
j_rov
Keith, tough choice... spend to keep it on the road with no extra value or let it go and cut your losses.
There are a lot of sellers on ebay offering a recon service, no matter what the condition of your engine, but please be aware they have terrible reviews (I researched plenty of them).
I've just done an engine change on mine and I reckon it cost me around £8k, and that was doing the install myself.
I did need 3 injectors, 2 turbos, 1 EGR, inlet manifold, intercooler, plus all the hoses, filters etc. etc.
Here's my write up: http://www.fullfatrr.com/forum/topic47199.html
If you do decide to go down the route of fixing, feel free to get in touch as it's all pretty fresh in my head.
Jon __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #482596 4th Jul 2018 10:28am
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
You seem to have made up your mind but in case not , turbos can be remanufactured for a lot less than 2k , i had my two done for less than 1k on my 3.6 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #482615 4th Jul 2018 2:00pm
