Home > General > What tyre inflator do you use? |
Hairy Dan Member Since: 22 Jul 2017 Location: NW Durham Posts: 177 |
I use one of these Ring RAC900
27th Jun 2018 12:24pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
I have a Michelin one, but I do run the engine while it’s running. It does run faster and pumps tyres up a bit quicker |
27th Jun 2018 10:02pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
One similar to this.
28th Jun 2018 10:09am |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
At home, a 13cfm compressor with a British Jamec PEM tyre inflator/pressure gauge.
28th Jun 2018 10:58am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
I can't understand why LR don't have a plug in outlet on the onboard compressor. Then all that is needed is an airline.
30th Jun 2018 10:51am |
160dmb Member Since: 16 Dec 2012 Location: Hertfordshire Posts: 452 |
Cayenne has that ability from memory - never used it though 2016 (L405) Autobiography in Black with Ivory - for ULEZ
10th Oct 2018 11:27am |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
I have a pump that was intended for space saver tyre kit, mine was made by Continental (or trade marked as such) but they are from Michelin as well, the power lead and air line pack up into the main body for storage and it is not very loud and much faster than a cheap pump bought before, have a look on eBay for one. David
10th Oct 2018 11:58am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1446 |
10th Oct 2018 1:09pm |
j_rov Member Since: 10 Jan 2017 Location: Warwickshire Posts: 385 |
^^^ DITTO ^^^ __
10th Oct 2018 1:28pm |
paddy_ffrr Member Since: 10 Oct 2018 Location: West Sussex Posts: 6 |
The Clarke units which combine jump start pack as well as compressor have served me well in the past... good value if you can stretch to it
10th Oct 2018 4:28pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
big workshop compressor, cant remember how many cfm but it has a 400 litre receiver (dual motor job, came from a spray booth previously).
10th Oct 2018 4:46pm |
Huwrhys Member Since: 07 Feb 2018 Location: Hornchurch Posts: 546 |
Same as Hairy Dan, Ring RAC900 and I find it reasonable. The gauge reads quite accurately and it works quickly. I find the on / off switch on the unit is not very user friendly as I really want it near the tyre I'm inflating. As the nozzle screws to the valve you can't just release it as you get to pressure, so have to run to where the unit is to turn it off. Then unscrew the nozzle. |
11th Oct 2018 5:54am |
ive got one ive had for years from Costco. Its starting to see better days now but works well enough for the time being. Think it is a Bon-Aire one. Has a nice long Flexi hose with it. There is nothing that can't be fixed with a hammer😜😜
14th Oct 2018 2:21pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 425 |
probably becasue it would exceed the duty cycle and shut down for being too hot just puffing up one tyre. Cheers James |
15th Oct 2018 9:14am |
