Home > Maintenance & Mods (L322) > Air Con blowing cold from one vent only |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i have this too, one vent blows warmer air then the other, but i know there is only one temp sensor located in the heater control unit. V8 facelift Range Rover Autobiography 22" wheels.
7th May 2013 10:41pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
I quote from Workshop Manual,
8th May 2013 8:51am |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Hmmm - I now seem to have these symptoms! The passenger side blows chilled air, but the drivers side is non chilled. However, if you turn up the temperature on the drivers side then it is happy to heat up. Could there be a flap stuck somewhere? My IID tool shows no HVAC errors however (which I would expect if one of the temperature switches was giving errors)... |
12th Jul 2014 6:36pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
I've also had these symptoms when:
12th Jul 2014 7:34pm |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 |
I can confirm I've had this twice and it was fixed with a recharge - seems I have a very small undetectable leak.
12th Jul 2014 8:30pm |
Richard Member Since: 05 May 2014 Location: Exeter Posts: 36 |
I have exactly the same issue, had Kwik fit do a recharge and after that all the vents were cold for a week. So it must be a gas leak. |
12th Jul 2014 9:46pm |
Thanks guys - off for a recharge (it's a few years since the last one)! |
13th Jul 2014 11:00am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Done a search and this thread seems to say a regas may cure cold from one side only.
30th Jun 2018 5:51pm |
