Home > Maintenance & Mods (L322) > Coolant leak |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6397 |
Sounds like the radiator has a hole, that is where it goes, ...or you have a weeping joint in the Front Left area somewhere.
15th Jul 2018 10:18am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1335 |
An easy start would be to put the car on the high suspension setting and then slide underneath the front and remove the plastic tray which runs from the back of the bumper to the front of the engine. Lots of little screws to keep safe. That will allow you to see the bottom of the radiator. My 2004 car needed a new radiator when one of the bottom corners started leaking, symptoms very similar to yours. The radiator replacement was not that expensive. Only Range Rovers since 1988 |
15th Jul 2018 12:32pm |
