Yes, the top bush is just held central only via an interference fit.
The Toe-Control arm has no adjustment at the knuckle (outer end). However it does have a cam arrangement (like the top bush bolt) to adjust toe-in at the sub-frame end.
If it's anything like the pair I've just replaced on ours, the bolt will be siezed in metal bush centre & the nut rusted solid on the bolt thread.
I had to cut the bolt at both ends with a reciprocating saw to remove the arm. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 145,000 miles & climbing
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
