Home > In Car Electronics (L405) > Auxillary Power Socket (main one) fuse / Troubleshooting
verydisco
Hi Gang,
On my 2013 4.4L L405, the 12-Volt auxiliary power socket (the main one by the cup holder) does not work.
I have looked in the owners manual, where all fuses are detailed, but can not find it. They detail the other plugs, but not the main one in question.
Does anyone know where it might be - or had a similar problem, please?
Thanks l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #485653 10th Aug 2018 6:20pm
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Could it possibly be fuse number 63 in the passenger compartment fuse box which is listed as Front cigar lighter (20 amps Yellow)? Confused Cheers Ian
Kielder 4x4 Safari
Post #485661 10th Aug 2018 9:37pm
abuss
Switzerland 2013 Range Rover Autobiography 5.0 SC V8 Firenze Red
good luck with changing fuses.
i do not understand how they can make such a big car, with so poor acces to the fuse box.
I had the same problem some months ago....I dont have big hands, but it is impossible to get in with both hands to change those flimsy ridiculous small fuses, and not dropping them...and there is no light.
Cheers Alex
Post #485905 13th Aug 2018 10:47am
verydisco
Well done Dan, I simply did not see it on the list before.
Access is a joke indeed. taking the 12 relay did help, but you'll still need thin fingers.
I'll post pics later. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #486731 21st Aug 2018 12:31pm
CS
Might artery forceps help with access? Available from fishing tackle shops as well as medical suppliers (used for removing hooks without handling fish). Only Range Rovers since 1988
Post #486744 21st Aug 2018 1:34pm
Long nose pliers work ok. Thumbs Up
Post #486748 21st Aug 2018 2:02pm
wealy
Did you get anywhere with this? I found fuse number 63 (pig t get to) and it was indeed blown, I changed it!!!!!! Murder of a job! But it still does not work?
Ive checked the fuse and its ok?
Post #496078 20th Nov 2018 3:30pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
I got my new (ish) L405 home yesterday and noticed the same problem. Fuse 63 was blown. My fondness for my new car was tempered slightly by the inaccessibility of the fuses behind the glove box mentioned earlier. Fuse 63 is the most cunningly obscured of all of them. Managed in the end to get the fuse out of slot 63 by first removing the relay to its right. Replaced the fuse with much swearing and now have two spare fuses floating about in the internals somewhere after dropping them. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2011 Discovery 4 3.0 HSE
2015 Discovery 4 HSE Lux
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #642875 13th Sep 2022 5:21pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
Today I had to change fuse 63....after an hour I was going to pop down to my local maternity unit and see if the on call gynaecologist could spare a few minutes. Bloody ell ! Trim off under glovebox, kick panel off ( once I'd removed the bonnet opening handle ) and large electrical plug disconnected...all just to change one fuse. Hang your heads in shame LR engineers/ designers.
Post #651405 21st Dec 2022 8:01pm
