Home > Maintenance & Mods (L405) > Oil service frequency - request for fellow owners experience |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7738 |
It would seem that the JLR diesels don’t take kindly to gentle treatment.
29th Jul 2018 7:11pm |
Montys 4x4 Member Since: 23 Dec 2014 Location: Suffolk Posts: 70 |
Hi,
30th Jul 2018 8:00am |
peanutbob Member Since: 03 Mar 2013 Location: UK Posts: 57 |
My 17yr VSE which I purchased from the dealer at 5k mileage - it was their finance directors car, requested an oil service at 7k miles. They applied a software update ref the dpf sensor, checked oil dilution rate which was 6.1.
30th Jul 2018 1:31pm |
JamesD Member Since: 21 Jan 2013 Location: Worcestershire Posts: 203 |
My car has done 36k and has had a service on average every 5k. We do 15k miles per year but in the week just short school runs which is clearly ruining the DPF regeneration. I really want to keep the car long term but am worried about premature engine wear 2021 L405 Vogue D300
18th Aug 2018 9:52pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3685 |
No help to you as mine is a TDV8 - but it’s just flashed up on the dash that an Oil Service is Required in 1500 miles - that makes it roughly a service at 14k intervals 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
18th Aug 2018 10:55pm |
As predicted service request flagged again at 17k miles. Back to dealer who said oil dilution rate 4.1 and all fine until the next service in Feb and not to worry until then. They couldn’t reset the service message as it’s over 75pc time until the next service so I have to ignore it in the interim! At least the car got washed but the front tyre at 30psi which showed an error message this week wasn’t inflated to the 32psi correct pressure. |
12th Dec 2018 7:59pm |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
I have a MY2016 TDV6 which has now done 42,000 miles.
12th Dec 2018 10:48pm |
This is the service bulletin ref oil dilution for the listed models. However, it states oil dilution above 6.1pc will trigger the service message, yet every time I take it in the oil dilution apparently is fine and today was 4.1 pc. Apparently. Also the last software update was meant to stop these messages appearing. It’s just rather worrying that I keep receiving the service required messages and the dealer service dept just says...what drama....no drama! Just keep on driving it and ignore!
12th Dec 2018 11:19pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I have a 4.4 SDV8 and it needed an oil change about every 13-15k miles (yearly) when I was working, however, I retired at the end of 2017 and around 3,000 miles after my last service (March 2018) , I got a service type message (can't remember the exact wording) and so took it to the dealer who said it was because it needed an oil change , the oil being 8% diluted with diesel). I said I had only done 3k since last service but they said it was due to my now mainly short journeys (although I did do at least one longer one - i.e. @100 miles - each month as I didn't want my DPF failing). I wasn't impressed at now apparently needing an oil change 2 times a year when only doing a third of the mileage I used to do on a single oil change in the past 3yrs. At least they did the oil change at the cost of the consumables and waived the labour fee to soften the blow for me, though I was over a barrel really (forgive the pun) as if I didn't have it done and had an engine issue, no doubt my not having the oil changed when the car required would be given as the reason.. Steve
29th Dec 2018 5:11pm |
Around 14/15k miles. I do drive quite spiritedly and also quite a few long journeys interspersed with short trips 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
30th Dec 2018 6:05pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Given the unfortunate oil dilution rates I wonder how long it will be before engine failures become commonplace.
30th Dec 2018 6:52pm |
Hi,
2nd Jan 2019 11:12am |
socialrover Member Since: 03 Dec 2010 Location: Yorkshire Posts: 135 |
Well done Paul for taking them to task and benefitting the rest of us at the same time .
2nd Jan 2019 8:19pm |
Lawnman Member Since: 03 May 2015 Location: Cheshire Posts: 33 |
Ditto the comments above. 17.5 MY serviced at 5k, or 6 months old. Booked in today for second service @ 10k or 15 months since new! Service indicator on again!
2nd Jan 2019 8:37pm |
