Home > In Car Electronics (L322) > Get 12v accessory to switch off with ignition
sgoode
United Kingdom 2004 Range Rover Vogue Td6 Bonatti Grey
Hi all
I am sure this must be covered somewhere but I cannot find it in a search. I would like my accessory socket to turn off with the ignition. I used to have an old Mondeo and you could reposition a fuse to switch off with the ignition if you wanted. Is there anything that simple on the Rangey?
If this is covered in another post, a link would be great.
Thanks
Steve
Post #487461 29th Aug 2018 5:52pm
Which accessory socket in particular? This might help you.
http://www.fullfatrr.com/forum/topic32623.html
Post #487467 29th Aug 2018 6:43pm
broncoupe
What year car do you have ?
Post #487670 31st Aug 2018 8:47pm
sgoode
The car is a 2004 and the accessory socket in the centre console in the front.
Post #487693 1st Sep 2018 7:38am
broncoupe
those instructions were spot on
you could also just add a fuse tap to the front fuse box, easy to buy off eBay
you need full sized blade fuse type
its what we do on later cars it means original circuit is protected by its fuse while allowing you to take a second fused take off.
Post #487697 1st Sep 2018 8:01am
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Then you have an L322, not an L405. This section of the forum is for the L405.
Mine is also a 2004MY L322 and I was complaining to myself this morning that it's bloody annoying that the accessory sockets turn off with the ignition and don't stay on when the switch is in the Accessory position. Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #487736 1st Sep 2018 12:42pm
sgoode
Oh crap. Apologies, if only I could read. Yes it is an L322 and it is annoying. I like the Mondeo idea where there are 3 slots for the fuse. In the upper position it stays live in the lower position it goes off with ignition. Really hoped there would be something similar for the Range.
Post #487737 1st Sep 2018 12:46pm
p38arover
It's odd that yours has the reverse configuration to mine. Wanna swap? Very Happy Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #487742 1st Sep 2018 1:04pm
sgoode
So how does yours do that??? :-0
Post #487774 1st Sep 2018 6:26pm
p38arover
No idea. I shall have to investigate. Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #487791 1st Sep 2018 11:44pm
