Home > Maintenance & Mods (L322) > 4.4TDV8 P040D-00(2F) EGR temp sensor A - Where's the sensor? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16165 |
Exactly what i hear often sir... Some do, some do-not!!! |
25th Aug 2018 6:41pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2301 |
Yes, Nino's pictures show the one in the EGR outlet pipe in the V, next to the oil cooler. |
25th Aug 2018 9:51pm |
Can you get to what appears to be a 2nd bolt retaining the rear heat-shield to loosen it in case that's enough to provide the needed clearance?
25th Aug 2018 9:57pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Hi Graeme, yes I managed to get the little 8mm bolt out. I bent up the top shield but it wouldn't get out of the way enough. I like your second suggestion, if I could find/make something that would hook/hold on the edge while I banged it, I think it would give enough space for the socket.
25th Aug 2018 10:11pm |
I think we can call that EGR temp sensor B . Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
25th Aug 2018 10:12pm |
Just a bit of an update but no progress..
9th Sep 2018 7:27pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
Had ours replaced whilst it was having some work done cleared the code must admit having looked at the access was glad someone else had the hassle 2011 4.4 TDV8 Autobiography |
28th Sep 2018 9:33pm |
Mine is in LR having the sensor/probe replaced! Amongst a heap of other works! |
28th Sep 2018 9:56pm |
I've tried several times but can't get it out. Not giving up but any tips from your guy GG????
28th Sep 2018 10:13pm |
GGs post also disproves the ghost code theory.
28th Sep 2018 10:15pm |
No, the 405's suffer exactly the same as the 322's... I have 7 mates with 405's and every one has had this sensor/probe issue! Interestingly 4 have had to have the drain mod carried out too! Come on JLR |
28th Sep 2018 10:35pm |
Were any of the L405 original sensors the revised design or were they all the early design? |
28th Sep 2018 10:42pm |
Im guessing at some point JLR fitted the revised sensors at point of build... Just don't know when that was... |
28th Sep 2018 10:49pm |
I even tried to make a tool to bend the exhaust heat shield - just to get the special socket on the bloody sensor!!!
28th Sep 2018 10:51pm |
