Home > Maintenance & Mods (L322) > Changing RR lettering- any tips.
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Going to change my front and rear RR lettering to black. I've seen a tool to attach to drill but £17 seems a bit excessive.
Any tips on how to remove the sticky residue left so i have a clean surface to re apply??
Post #49051 5th Feb 2011 9:35pm
tboner001
England 2014 Range Rover Autobiography SDV8 Fuji White
Use a hair dryer or a hot air gun on very low (and take care if hot air gun not to heat up to much) first to remove the letters with either a plastic scraper or old debit card etc. then use white spirit or acetate to remove any sticky crap left then stick your new ones on and put some polish on the paint around the area to protect until the next detailing is done.
Post #49058 5th Feb 2011 9:56pm
Nickj
So with the white spirit and the sticky residue is it just a case of rubbing for a long time with a cloth?
Post #49061 5th Feb 2011 10:19pm
p-trax
Japan 2011 Range Rover Vogue 4.4 V8 Santorini Black
Pouring hot water on the badge softens the adhesive foam enough to allow you peel the lettering or badge off, leaving no residue Thumbs Up Gerry
____________________________________________
Arrived>Santorini/Jet FFRR MY11 TDV8
Gone>Stornaway/Ebony MY09 RRS HST TDV8
Gone>Java black/Ebony MY07 RRS HSE TDV6
Post #49062 5th Feb 2011 10:21pm
daveo
dont forget to mark the level of the badge, i did this with masking tape at the far edge of the tail gate and a straight edge, V8 facelift Range Rover Autobiography 22" wheels.
Post #49067 5th Feb 2011 10:48pm
