Home > In Car Electronics (L322) > anyone near stoke on trent
jk3528
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
is there anyone near stoke on trent with a l322 from about 2003 that will let me plug in my audio bits to see if I can work out which ones are ok and which arnt
at the moment I just get nothing on the screen
or sound
I have tried another screen but still the same
so it can only be one of the boxes in the back (or the wires)
help
julian 07504115743
Post #491296 7th Oct 2018 12:41pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Not Stoke, though a little north of you - junction 19 of M6. Any good? Current:
- 2013 L405 4.4 TDV8 Vogue
Sold:
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #491642 9th Oct 2018 9:07pm
jk3528
Could be what radio setup have you got?
Post #491654 9th Oct 2018 11:22pm
gj88
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Have you tried cleaning up all the connections to remove any gunk etc from any previous water ingress?
Post #491756 10th Oct 2018 6:49pm
jk3528
Yes but with the IID tool it can’t find any of them
Post #491758 10th Oct 2018 6:54pm
gj88
If you've cleaned up all the connections properly, have you tried looking to see if any of the pins have got bent or broken over time. I recently had my screen go, there was a missing pin in the connector into the tv module. Swapped the unit out for £30 and it's working fine now. It could be some damage to one of the boards that you can't see without taking them apart but there's every chance there'll be a fault you can spot. Don't think you'll find anything with the IID, mine didn't flag anything
Post #491766 10th Oct 2018 7:47pm
jk3528
Checked the boards taken the covers off
There was some furring to the satnav which I cleaned up
But still nothing so thinking it maybe the wiring
Post #491779 10th Oct 2018 8:07pm
Zebedee
Standard vogue with Satnav. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #492001 12th Oct 2018 7:06pm
jk3528
This has the screen with cassette behind it
Multi cd in glovebox
Radio sat nav video and 2 amps in the back
So when I get it up and running I’ll bring it up if I can ?
Post #492019 12th Oct 2018 8:44pm
Zebedee
Yes by all means, sounds exactly the same as mine. Current:
Sold:
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
Post #492047 13th Oct 2018 7:36am
