Home > My Range Rover > Cold Turkey over, think I've found my next one! |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
3 months and 4000 miles in and the FF has been faultless, really happy with how it goes. Bit thirstier than had hope (26mpg average) but it isn't half rapid when it needs to be
14th Jan 2019 8:51pm |
While you’ve got it off, replace the 4 short manifold hoses onto the plenum. These are renowned for failing at some point and are about £100 for a set. did mine the other ween and the intake plenum needed to come off for that. Also remove the throttle body from the front end of the plenum, and give it a good clean.
14th Jan 2019 9:08pm |
Moving on to what we came here to do This is my oil cooler, looked pretty messy so suspect the seal was leaking here.
14th Jan 2019 9:12pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Fantastic guide!
14th Jan 2019 9:19pm |
As NMJ says, try to avoid water contamination into the oil, I let the water drain out fully from the connections before removing the cooler then used a suction tube to suck out all the remaining oil and water from the mounting plate.
14th Jan 2019 9:30pm |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 |
Wow, that is some great documentation! 2010 RR SC
17th Jan 2019 5:58pm |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 |
Good work Paul.
17th Jan 2019 7:38pm |
Thanks guys, hopefully contributes to the overall usefulness of this great site
17th Jan 2019 8:44pm |
plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73 |
Does anyone know the torque settings for the bolts around the oil cooler. |
13th Feb 2020 8:18am |
Apologies just read the post 3 up and saw 10nm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
Stan - is this in the wiki? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
13th Feb 2020 8:46am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
yes it is Rob... ... - .- -.
13th Feb 2020 9:39am |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1243 |
Thats a cracking looking car that is factory and thats the best way. Glad you got your issues sorted. |
13th Feb 2020 5:52pm |
Swapped the 2 oil cooler seals and oil pipe O rings on mine yesterday.
14th Feb 2020 7:58am |
