Home > Technical (L322) > TD6 battery light |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 |
Do you have a digital meter to check if the vehicle is charging put it on the battery then rev vehicle and see if the meter rises to show a charge from the alternator or even an iid tool you can plug in as that will show if the vehicle battery is been charged |
16th Oct 2018 9:57am |
Teaspoonasaurous Member Since: 08 Jul 2018 Location: Cambridge Posts: 73 |
No digital meter, but I do have an iid tool. I'll run that through it now. |
16th Oct 2018 10:49am |
Plug it in and on your iid app up on the top it will show your voltage from the alternator give car a rev see if it goes up should be around 14volts |
16th Oct 2018 11:11am |
So I only have an iCarsoft not the full big daddy tool. The only thing that I could see was to read the battery output datastream that was 11.4 and it didn't budge when I revved the car. |
16th Oct 2018 2:39pm |
SandySix Member Since: 13 Sep 2018 Location: Chippenham Posts: 44 |
Sounds like a lack of charging then.
16th Oct 2018 2:48pm |
Is there any quick way to check if it is the belt vs the actual alternator? |
16th Oct 2018 3:11pm |
If there is a belt on it and not squealing like mad.. it isn't the belt! |
16th Oct 2018 3:22pm |
Definitely no squeals...
16th Oct 2018 4:58pm |
NOW squeals.. as in it has just started?
16th Oct 2018 5:31pm |
Start the car then look at the alternator pully if it's going round and no noise from the belt then alternator is at fault |
16th Oct 2018 7:55pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I would say the battery light is the charging voltage light not how much the battery is charged so a longer trip won’t help.
17th Oct 2018 5:36am |
It certainly lets you know once the battery is dying. It through every single fault imaginable, airsusp, transfail safe, Hse anything else you can think of.
17th Oct 2018 11:03pm |
Good news, the L322 certainly likes a good battery and alternator , out of interest what does your charge voltage read now, 14.5 would be nice ? |
17th Oct 2018 11:15pm |
