Home > Technical (L322) > TD6 will not crank - immobilizer or other issue? |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
yeah right can get very fustrating. |
29th Sep 2018 10:00pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
All part of the fun I guess ..... |
29th Sep 2018 10:24pm |
PIMCO Member Since: 30 Jul 2018 Location: Oslo Posts: 44 |
Thanks for the extensive contribution, guys!
1st Oct 2018 12:10am |
OK, one step at a time, you have probably done this but look at notes on attached and confirm.
1st Oct 2018 10:12pm |
ignition switch has 3 positions, auxiliary, ignition and crank as you know. Auxiliary and ignition positions are fed by fuse 53 jointly when key in auxiliary position the purple /black wire from the ignition switch feeds fuse 39, fuse 39 then feeds position 11 of connector 0059 - the immobiliser ECU and that same purple / black wire splits of and feeds position 11 of the steering lock ECU when the key is in the ignition position - fuse 31 is fed via a green wire which in turn feeds position 10 of the steering lock ecu. when the key is is n the crank position as previous post fed by 60 amp fusible link 2, the black and yellow wire feeds position 2 of the immobiliser c0059 connector which in turn feeds the starter motor via a black wire from position 1 of the immobiliser ecu connector c0059 Simple as that !! I'm sorry I cant get this any clearer, trying saving it to your desktop maybe. This is zoomed in a bit and screen shot but still looks crap |
1st Oct 2018 10:39pm |
Thanks for the diagrams and excerpts!
2nd Oct 2018 1:10pm |
The immobiliser will only allow the crank when all parameters have been met which will be key code, neutral or park etc all which feed into the EWS immobiliser and only when it gets everything it needs it will allow the crank. You need to start with the above and confirm all of those feeds work and in the correct key position and then if that is all ok you can move on to what else might be missing as far as feeds into the immobiliser.
2nd Oct 2018 4:16pm |
Any luck or are you sticking with the switch starter? |
9th Oct 2018 8:19pm |
Apologize for my delayed reply.
15th Oct 2018 11:34pm |
Good news, thanks for updating the thread, well done for persevering. I was hoping you would trace it, when you said you didn’t have a feed going to the starter it was just a case of following it back from there I guess but your extra tracker and immobiliser didn’t show up on any of the wiring diagrams
15th Oct 2018 11:50pm |
Yeah, exactly - I had no reason to suspect that sucha thing would be installed. I guess it's kind of a cool gimmicky feature. But I'd venture to guess there is no way of hacking the EWS and stealing these cars without a key, so kind of overkill, no?
16th Oct 2018 12:25pm |
The security is very good but I’m sure with the right electronics somebody would crack it but hard to believe as they are hard enough to start when you have the key, secondly , why would anyone steal one ! |
16th Oct 2018 2:55pm |
Hehe, true that. I guess it was a more relevant when these were still rolling off the assembly line.
19th Oct 2018 11:44am |
You can certainly manage all impending faults, selling it quickly is the best way
19th Oct 2018 6:53pm |
