Home > Technical (L322) > Key battery problem. |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
Help please,
8th Nov 2018 4:01pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34907 |
bad news Mike...
8th Nov 2018 4:09pm |
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 |
My apologies if this is slightly off-topic but when you change the battery in one of the remote key fobs, do you have to re-sync the keys so that you maintain the driver personalization settings that are designated to that key number? |
8th Nov 2018 4:30pm |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
I don’t know what key you have but I’ve read about people changing keys and dropping the little black but that links to the car, sounds like it looks like a small piece of plastic but it’s inportant. Someone with more knowledge than me will explain more I’m sure. |
8th Nov 2018 4:39pm |
Thanks all.
8th Nov 2018 4:40pm |
i did mine recently so no re-code after battery change Mike, good luck chap |
8th Nov 2018 4:43pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 428 |
I changed myspare fob battery last week and no recoding needed! Cheers
8th Nov 2018 5:52pm |
Jomo Member Since: 26 Mar 2018 Location: Maidenhead Posts: 32 |
There are a few posts on here that suggest that the remotes can be sensitive to the brand of battery. Might be worth trying to get hold of a different brand. Duracell seem to get mostly positive comments and worked for me. 2011 5.0 S/C |
8th Nov 2018 11:55pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
+1 with Jomo, and check that you have put battery right side up (it has happened)
9th Nov 2018 10:25am |
Friday morning update.
9th Nov 2018 12:32pm |
good news mike...all the best to your son and his bride..... |
9th Nov 2018 12:44pm |
Thanks Stan.
10th Nov 2018 9:30am |
I have just opened a brand new strip of 5 Maxwells CR2032 batteries, dated Expiry date 12-2024 and out of 4 of them in Fob No.2 not one works. That fob had a Panasonic. battery in which I have refitted, and it works perfectly, but is giving low battery warning.
10th Nov 2018 2:34pm |
Updated Monday 14th Jan.
14th Jan 2019 10:08am |
