Home > Maintenance & Mods (L322) > Help needed urgently on suspension |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
Do you have a bluetooth iid tool? This has a pretty foolproof guided suspenson height setting utility that sequences you through each cormer setting it back to the default height (493mm front / 483mm rear) using up/ down arrows, very easy to do, assuming no faults with any of the height sensors etc. |
17th Nov 2018 3:48pm |
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2281 |
thanks for your reply, No I don't. The garage has a pro tool they plug in |
17th Nov 2018 3:56pm |
Check that one of the sensors isn’t 180deg the wrong way. Maybe when the did the arm it got messed with.
18th Nov 2018 10:36am |
good idea, thanks! |
18th Nov 2018 10:57am |
