Home > Technical (L405) > Overrevving ‘run a way’ TDV8 then engine died
Page 6 of 7 <1234567>
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
And it hadn't had the turbo drain mod done! 2012 Full Fat RR 4.4 TDV8
2006 VW Touareg 3.0 TDi V6
Post #495416 12th Nov 2018 8:53pm
Richardince
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
How can you tell that?
Post #495417 12th Nov 2018 8:57pm
GraemeS
The drain pipe pictured is not the L322's original, single drain nor the replacement twin drain. The pictured drain has 2 outlets from a single drain from the turbo and has a clamp fitting to the block whereas the twin drain uses a piece of hose with hose clamps for its higher-up outlet. Hence the turbo failure can't be attributed to a single drain.
I'm not so sure that the right-angled corners are the best design for oil that has to fall away from the turbo with minimal resistance though.
Post #495423 12th Nov 2018 9:22pm
Richardince
Has anyone a photo or part number of what I need to have it changed for?
Post #495425 12th Nov 2018 9:39pm
AJGalaxy2012
Post #495426 12th Nov 2018 9:41pm
GraemeS
Your old engine's drain was already a twin drain, just a different style to the one applicable to engines made before the 2nd drain was incorporated when the engine was built. Your twin drain can't be fitted to earlier engines and vice-versa because your block had allowance for the 2nd drain when manufactured, as evidenced by the press-in fitting and single retaining bolt.
I suspect that your vehicle's vin is higher than 160137, the upper limit mentioned in TSBs for smoke and DPF problems caused by the single drain.
Post #495432 12th Nov 2018 10:09pm
Richardince
Regretfully turbo oil feed seals (comes with pipe) are not available from JLR till November 30th so it’s going to be off the road into the 8th week.
If anyone has these please let me know.
Regards
Richard
Post #495632 15th Nov 2018 11:02am
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
I assume looking at the workshop pictures it is an approved service centre rather than main dealer in Suffolk doing the work?
Post #495634 15th Nov 2018 11:33am
GraemeS
Unfortunately the seals wont last and will have to be replaced with Viton seals in a few years, along with the oil filter housing gaskets but maybe LR will be providing gaskets that withstand the heat by that time.
Edit: If you're paying for the new seals/pipe then you could ask to have BS611 Viton seals fitted, sourced either by the repairers or yourself from a bearing and seals supplier.
Post #495676 15th Nov 2018 7:42pm
mrtidy
United Kingdom 2009 Range Rover Vogue SE TDV8 Zermatt Silver
How are things going with the replacement engine Richard? Hope it's all sorted. 2009 Vogue SE Zermatt silver
Post #497806 6th Dec 2018 9:13pm
Richardince
8 weeks on Saturday and have only just got the replacement oil feed pipe with copper seals. Engine can at least start to go back in. Still waiting for some other seals and if they arrive should get the car back at the end of next week.
Post #497809 6th Dec 2018 9:39pm
mrtidy
Hopefully a nice Christmas present for you. Thumbs Up 2009 Vogue SE Zermatt silver
Post #497810 6th Dec 2018 9:56pm
GraemeS
Richardince wrote:
It was the right turbo that failed , left hand side looking at front of car.
In case anyone missed it, this is the primary turbo.
My throttle closer has been fitted for 2 weeks and today one was fitted to my son's 3.0 D4. 2 will be fitted to my brother's 3.6 TDV8 RRS in a few weeks, 1 for each butterfly. It closes the throttle butterfly for 30 seconds every time the ignition is switched off to ensure that a runaway engine will stop when the ignition is switched off. Its a pity that LR hasn't programmed this simple action into the ecm.
Post #497995 9th Dec 2018 11:45am
gonna_go_double_r
Nice one Graeme, any pics?
I did miss that this was the primary turbo. What's interesting is that the drain mod relates to the secondary turbo, so OP has nothing no do with whether you have had the drain mod or not. Reassuring for me and anyone else who has not had the mod done.
Hope you're back on the road now or very soon Richard.
. now: gone_double_r | 2011 Vogue SE 4.4 | Stornaway | Lovin' it
Post #497999 9th Dec 2018 12:13pm
GraemeS
Did you spot that a twin, factory-fitted drain was fitted to this vehicle and therefore contributes nothing to the single/twin drain discussion?
Post #498005 9th Dec 2018 12:53pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
