Home > Technical (L322) > New ignition switch fitted, not cranking |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Check the continuity of the new switch
7th Dec 2018 6:52pm |
Qahmed95 Member Since: 28 Jan 2017 Location: Birmingham Posts: 27 |
Do you know pins I need to check continuity through.
7th Dec 2018 7:11pm |
No but you should be able to work it out from the loom. One will be a common ground. The others will be the various live feeds. They should all give a value through the common ground. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
7th Dec 2018 7:25pm |
So checked all the connections in both positions of ignition, all are the same except for the black and yellow wire going to the EWS unit. On the new switch, when turning to crank it over, there's a reading of 0.13 v and drops to 0, and on the old one it goes to around 12v before going back to 0. |
8th Dec 2018 12:07pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16163 |
I haven't touched one of these for ages but aren't they coded to the car? Hence why your immobiliser won't allow the starter to engage?... |
8th Dec 2018 12:13pm |
From what I've read, the ring antenna is above the switch and that's what sends the key info to the EWS. So this should theoretically work without any coding. |
8th Dec 2018 12:19pm |
So, exactly what have you changed? |
8th Dec 2018 12:22pm |
Just the ignition switch. |
8th Dec 2018 12:27pm |
The metal barrel or the electrical black box?
8th Dec 2018 12:29pm |
So just changed the electrical box, I opened it up and found some black residue on pin 8 which is for the EWS, I was cleaning it as I was replying to you. Just installed it in the car and it's running perfectly now. The residue was only on the one contact, that's why the ignition was working but it felt as if the immobiliser was not allowing the engine to turn over. |
8th Dec 2018 12:33pm |
8th Dec 2018 12:38pm |
Great news |
8th Dec 2018 12:39pm |
