Home > Technical (L322) > turbo solenoid with variable geometry alarm |
Bluewater9118 Member Since: 07 Mar 2016 Location: Angerville Posts: 31 |
Hello everyone
9th Dec 2018 8:50pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Oh and Bluewater9118 check your rubber inlet hoses. These feed into the 'donut' top of the engine intake. The hoses can crack and is often the cause of sudden restricted performance. They can crack underneath the clamps so you are best to remove and check. If they are fine, then this can be eliminated.
9th Dec 2018 9:47pm |
I trust my mechanic, he will do all that is nescessaire before entering in big expenses.
10th Dec 2018 5:21am |
Ok - good you trust him.
10th Dec 2018 7:34am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3671 |
It could possibly be The CSOV.
10th Dec 2018 9:14am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Bluewater9118, here is the picture of the part Baltic Blue is talking about
10th Dec 2018 10:56am |
Where is that on the engine Nino?
10th Dec 2018 11:48am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2298 |
The valve can be seen if you look down directly behind the radiator, middle right side when looking towards the engine. The different pivot for the vacuum chamber of the later version is quite easily identified. |
10th Dec 2018 11:59am |
here you go Greg,
10th Dec 2018 12:51pm |
By removing the plastic under engine tray it is much easier to access the valve to squirt a bit of penetrating oil and or, as I do before the winter months , apply a squirt of lithium grease to prevent corrosion by winter road salt.
10th Dec 2018 5:09pm |
J can now give you the errors codes:
10th Dec 2018 6:15pm |
Google translated it:
10th Dec 2018 6:27pm |
From the Workshop manual:
10th Dec 2018 6:33pm |
P 1247 seems to cover the CSOV stuck problem.
10th Dec 2018 7:17pm |
