Home > Technical (L322) > Dead Range Rover L322 (no medium speed canbus) |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 334 |
I'm guessing they've checked the obvious, battery and alternator?
26th Jul 2018 3:22pm |
Kevrobbo1961 Member Since: 25 Jul 2018 Location: Staffordshire Posts: 7 |
i stuck a new battery on it for them last week Andy at a cost of £198 iv`e been in the motor trade for 40 years and it`s blown me away that a low voltage problem can cause a problem as big and as expensive as this, JLR need to have a really good look at themselves.... |
26th Jul 2018 3:44pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Hi Kev
26th Jul 2018 3:49pm |
Hi Matt,
26th Jul 2018 4:51pm |
buck66 Member Since: 28 Feb 2016 Location: Ontario Posts: 5 |
Hi Kev, I experienced a very similar issue with my 2010 RR HSE 5.0L V8 (North American version).
2nd Aug 2018 11:20am |
Hi Folks,
7th Dec 2018 1:58pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
That is really good of you to post back your solution, so many don’t bother once their vehicle is fixed. |
9th Dec 2018 9:29am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
It's crazy how that unit can cause such a problem. Fair play to you for persevering & reporting the outcome |
9th Dec 2018 10:22am |
tony66 Member Since: 30 Nov 2014 Location: fife Posts: 92 |
would unplugging the unit allow the rest of the car to work normally...? |
9th Dec 2018 10:23am |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 685 |
Similar problems here! Can’t even get my ignition lights on at the moment! Car has thrown up almost every fault available, hit a huge puddle last week! Whether that has any consequence!
9th Dec 2018 10:24am |
Hi, it`s the least i could do to post the out come,someone might find them selves in a similar situation and could save themselves a fortune,
11th Dec 2018 5:18pm |
RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 46 |
Thanks for the update Kev. U 2010 TDV8 3.6 Galway Green |
12th Dec 2018 12:51pm |
so if the earlier work hadnt been done more than likely it would have been fine unplugging the effected module...?
12th Dec 2018 1:26pm |
possibly, the only thing is as soon as you see smart key not found on the dash and you plug it into the laptop you automatically try to retrieve the key program, by doing this you lose all the codes from the smart key because there`s a break somewhere in the medium speed can system, this will then lock down the KVM stopping you from being able to program the key`s to the KVM because it thinks it`s being stolen and leaves you with a dead car,
12th Dec 2018 2:14pm |
