Home > Technical (L322) > L322 TD6 Front Brake Pads - Spring Clips into Piston
stuart_2006
On the Rimmer website there's a video showing how to change the front brake pads on a TD6. The pad that sits against the piston has got some springy clips that hold it to the piston. Just got a set of Mintex pads to fit and those springy clips are not present. Just want to make sure that that is not a problem …?
Thanks.
Post #498616 14th Dec 2018 6:43pm
tony66
Scotland 2005 Range Rover HSE Td6 Tonga Green
pads
i just bought pads for mine-i think there are two types[not inc the brembos] one has ears with little anti rattle shims-the other has the big clips you describe...i may be wrong and havent fitted mine as yet
Post #498618 14th Dec 2018 6:50pm
Weegie
To th OP - re_use the spring clips that are already there. They aren't normally supplied with new pads. John
GAP iiD BT
Post #498620 14th Dec 2018 6:56pm
stuart_2006
OK, so it looks like the front brakes changed for the 6A VIN. The Rimmer video shows the pre-6A version. Looks like I've got the correct parts - looking at my brakes with a torch through the wheel slots, I've got the 2 spring clips per side, and there are two bolts to remove the calliper carrier each side - two pairs of replacement bolts came with the pads.
Post #498662 15th Dec 2018 12:22am
