Home > Technical > Genuine Brake Part numbers- TD6 & 4.4V8 models
United Kingdom 2008 Range Rover TDV8 Vogue SE Auto Stornoway Grey
I had to find this out as mine is a facelift model and everyone seems confused as to which brake pads to use.
A LR Dealer will give you a definitive answer from your reg number or VIN but this is what I found out.
The front and rear brake pads were changed from chassis number 58******* onwards. You'd think they'd be more expensive but they made them cheaper for once. The difference is they are smaller.
I only have the rear pad part numbers at the moment
L322 02-05 MY Pre 58****chassis number
Part No. SPF000120
L322 06MY->
Part No. SPF000140 THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
http://www.fullfatrr.com/forum/topic666.ht...vented#end
2008MY TDV8 Vogue SE, Stornoway/Jet/Piano/ RSE+DVD
2003 Defender 90 TD5 Hard Top Ruggedised
*Gone: Range Rover Vogue TD6, JE Stage 1
*Gone: Range Rover Sport Supercharged 4.2V8
*Gone: Range Rover Vogue Classic 3.9 Auto
*Gone: Land Rover Series 3 SWB
Post #723 1st Aug 2008 10:47am
The Flying Scot
Scotland 2004 Range Rover Td6 Vogue Auto Oslo Blue
Hi
I change both front and rear pads a couple of months back..including new wear sensors. I have a 04 Plate and the genuine part numbers were..
Front
Pads = SFC500050
Sensor = SEM000012
Rear
Pads = SFP500120
Sensor = SOE000011
Hope this helps 2004 Range Rover Vogue TD6
Post #4910 13th Apr 2009 2:30pm
View user's profile Send private message Reply with quote
Ivan
Ireland 2005 Range Rover Supercharged Vogue SE Auto Zermatt Silver
Ferodo nos. for an '05 S/C with Brembos
Front FDB 1996
Rear FDB 1613
About £40 a set, depending on where you buy
Ivan FF RR S/C (for sale)
TVR Chimaera 500(Gone)
TR7 V8
Post #5431 6th May 2009 3:09pm
Update: All Genuine Parts & Prices
These parts are for facelift cars (TD6 & 4.4V8), from 05 registration onwards, 06MY onwards. These are NOT for Supercharged 4.2 Brembo brakes or TDV8 models.
Prices are genuine Dealer Parts department. ALWAYS ask for 10% discount ontop, they never say no.
Front Discs: SDB500182 £48.67 +VAT each
Front Pads: SFP500010 £60.64 +VAT per set
Front Sensor Wire: SEM000012 £14.61 +VAT
Rear Discs: SDB500202 £48.67 +VAT each
Rear Pads: SFP500140 £44.00 +VAT per set
Rear Sensor Wire: SOE000025 £8.27 +VAT THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #5496 11th May 2009 9:53am
2002-2005 Brake Disc Part numbers - Front & Rear
2002 to Vin range 5A999999 TD6 & 4.4 V8
Front Discs: Genuine Part Number SBD000201
Rear Discs: Genuine Part number SBD000211 THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #5501 11th May 2009 11:15am
noddy
United Kingdom 2002 Range Rover Td6 Vogue Auto Zermatt Silver
There is a company on ebay selling new discs and pads quite reasonably. Front with pads £68, rear with pads £54. delivery around £10 per item. I've just emailed them to see how much for the lot in one delivery. 02 Vogue
Post #5919 1st Jun 2009 11:54am
more importantly check the brand and where they were made, i've been told to avoid chinese made. THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #5924 1st Jun 2009 1:30pm
dan_uk_1984
I tend to go for cheaper (£20 a set) pads, my theory is that being made of what I presume is out of date cheese (although, does cheese ever go out of date or does it just get more expensive?) they tend to wear about 25% quicker than OEM pads. This means the discs last a lot longer.
I've currently got Bearmach on the front and Mintex on the back. These are now £16.99 at Island 4x4.
I actually think they stop better than the OEM's, but that may be my imagination. But they do throw out a whole load more brake dust than the OEM's. I notice that Island 4x4 now do the pad wear sensor too for £9.99 - Barjin!
Post #5927 1st Jun 2009 2:08pm
RRVSE
United Kingdom 2006 Range Rover Td6 Vogue SE Auto Java Black
Just had rear discs + pads and front pads fitted on my 2006 56 Plate FFRR 3.0d and parts listed as:-
SOE500030 - (TP) Sensor Assembly - front @£15+vat
SDB500202 - (TP) Disc - rear @£103+vat the pair
BDA0150 - Brake cleaner @ £5+vat
SFP500010 - (TP) Pad - front @£57+vat (actually ferodos)
SEM000012 - (TP) Sensor Assembly - rear @£18+vat
LR016808 - (T) Kit - Brake Lining - rear ferodo pads?? @£47+vat
From this topic, itl ooks like I could have maybe done a bit better on the prices but they seem comparable.
The LR01608 kit above is the only thing confusing me, I'm assuming it is the rear pad set (SFP500140) with some other ancilliary stuff bundled together. Anyone know? (I should have asked the Service guy).
Steve Steve
Main car : FFRR Vogue TD6 SE (06MY - Sept)
Other car : Vauxhall Lotus Carlton
Past cars : LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #5945 2nd Jun 2009 2:05am
noddy
the discs are from Bearmach - www.bearmach.com - and the pads are mintex
Link to ebay auction:
Rear: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...0152207717
Front: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...0199232381 02 Vogue
Post #6914 13th Aug 2009 7:26pm
RRVSE
Just out of interest, both my rear discs rusted about 4 weeks after they were fitted (the hub part) and I complained to the dealer as I reckoned they looked unsightly and asked where they were sourced from and was told they were standard LR issue (so can only assume LR are using another supplier). I mentioned that the ones they took off weren't rusty and nor were my front disc hubs and they had both been on for almost 3yrs!! As I got no joy, I'm now planning to paint the hubs with some high heat aluminiun paint I used on my other cars exhaust manifold.
Steve Steve
Post #6962 17th Aug 2009 1:59am
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2012 Martin Lewis
