Home > Maintenance & Mods (L322) > Brake pad warning |
I never had any problems with Mintex or such.
1st May 2011 1:17pm |
Captain Slog Member Since: 16 Jul 2010 Location: Derbyshire Posts: 49 |
Hi Dan Thanks for the advice. Why does the sensor have to be replaced? _________________ Currrent: 2005 FF Range Rover L322 Vogue TD6 Gone: 1999 Range Rover P38 HSE TD6 Gone: 1985 Land Rover 90 SWB diesel |
1st May 2011 1:28pm |
The sensor activates by wearing through a wire as it comes into contact with the disc - there is usually about 3mm left on the pad at this point. There are only two sensors on the car, one front and one rear which means if you have a binding calliper you can chew through one set of pads and get no warning. So when taking the pads out, check for even wear. Dan |
1st May 2011 1:38pm |
Thanks for the support Dan. _________________ Currrent: 2005 FF Range Rover L322 Vogue TD6 Gone: 1999 Range Rover P38 HSE TD6 Gone: 1985 Land Rover 90 SWB diesel |
1st May 2011 1:50pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
if you know your pads and discs are ok, then it could be that the wheel has worn through the wire and caused a short circuit, this is what happen on my front sensor (which is on the passenger side front wheel, rear sensor is on drivers side rear wheel) if you find that the wheel has worn through the wire make sure to check the brake pipes as it is a common problem for the wheel to rub through the rubber brake pipes when the wheels are turned to full lock.
1st May 2011 6:05pm |
