Home > Maintenance & Mods (L322) > range rover td6 niose |
iowdave Member Since: 03 May 2011 Location: isle of wight Posts: 38 |
hello to all this is a first post and a difficult one...i have a 2003 td6 the problem i have is when i accelerate i get like a rough exhaust niose from the front which sounds like the exhaust is split but its not it dont do it all the time but it makes the car to niosey inside drives me mad.. i have been reading on here.. could it be the waste gate valve on the turbo?..thanks for reading and i would very much appreciate any help thank you |
3rd May 2011 7:47am |
paul_h_8 Member Since: 09 Jun 2010 Location: North East - England Posts: 256 |
Had something similar in mine before turned out to be some cheap gasket might have been intlet manifold gasket will check recipts when back at home.
3rd May 2011 8:42am |
hi paul thx for the reply id appreciate it if you would . |
3rd May 2011 9:05am |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
If it has only started recently it could be the viscous fan spinning?
3rd May 2011 10:42am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34871 |
has you mpg gone down recentely?..it could be a hole in the turbo cooler which is under the radiator .. ... - .- -.
3rd May 2011 11:03am |
hi and thx for the replys its been doing it for a while now but it sounds exhaust. as i hear it from the drivers side it sounds like at me feet sometimes i can throttle and nothing other times like being in a tin can. |
3rd May 2011 11:26am |
if the exhaust 'cat' is under where you say then it could be broken inside causing the noise ... ... - .- -.
3rd May 2011 11:30am |
ok thanks il start looking there..id just like to say thanks very much for all the replys i will post the results once i have cured this problem |
3rd May 2011 5:30pm |
3rd May 2011 5:36pm |
yep no problem i will forward any progress i make... |
3rd May 2011 7:48pm |
hi all an update on my problems i change the front precat and the main cat and the noise has all gone so must of been something to do with them thanks for all the replys and i hope this is useful to other members .. |
10th May 2011 7:31am |
