Home > Maintenance & Mods (L322) > Front & Rear Discs & Pads Change |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
i haven't done this yet as mine had all new on when i bought it, but i should imagine it will be fairly straight forward and a socket set, a screwdriver of suitable size to take screw from disc and maybe a windback tool to make pushing the pistons back a bit easier.
23rd May 2011 1:14pm |
RANGEROVER Member Since: 25 May 2010 Location: EAST OF ENGLAND Posts: 48 |
http://www.fullfatrr.com/forum/post58491.html#58491
23rd May 2011 2:00pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34906 |
there are a few yubey tubey videos on this.. |
23rd May 2011 2:26pm |
Certainly one of the easier jobs one can do in terms of Pads, but personally I had great trouble getting my discs off. You should have a big hammer to hand, and of course decent axle stands.
23rd May 2011 2:48pm |
Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94 |
thanks alot lads! going to get it cracked tomorrow, give the minging calipers a lick of paint, post a few pics |
23rd May 2011 9:22pm |
tilemanvogue Member Since: 22 May 2011 Location: Aylesbury Posts: 24 |
Hi Wiggins I have just done that with mine, you will need an allen key to remove the callipers, thought it was a star socket first, but no (you probably know this) but found it very easy, hope this helps Discovery 3.9 Range Rover 4.6 HSE 1998 L322 Range Rover Vogue 4.4 2004 |
26th May 2011 12:55pm |
If you're taking off rear discs then remember to back off the handbrake adjusters beforehand. If you have EPB (as opposed to a proper lever) then remember to put in service mode 1st. If that applies for any reason whilst you're working on it, it can remove fingers etc.
26th May 2011 1:01pm |
...and take the opportunity to adjust your handbrake so you dont have to pull it all the way up for it to engage. |
26th May 2011 1:10pm |
Got them all done today, didn't have a 7mm allen key socket small enough so just took off the carrier to get into it, tightened handbrake, gave the brakes a good bleed and car feels like brand new, the grooved and drilled discs look brilliant also with a good lick of paint makes it look 100 times better
26th May 2011 1:16pm |
