Home > Maintenance & Modifications > Front Light Guard fitting : How to
United Kingdom 2008 Range Rover TDV8 Vogue SE Auto Stornoway Grey
I just fitted the OE front lamp guards to my car and have to say the instructions could be better.
if you are doing them, here's the best way to do it:
Offer up the guard to the light and check how they will look. Stick the paper template to the front wing as shown and drill the holes.
Use araldite or similar to secure the little plugs in the wing, when its set, screw the mounting strip on. There is a double skin in the wing, it is safe to drill through both.
Offer up the guard, affix the side screws into the mount and THEN mark the holes for the front two holes.
Drill these last and then fit as shown.
It shows in the instructions to use the flat head screws for the mounting strip on the front panels, however they are not long enough and you need to use the round head ones instead. It makes no difference, they all fit ok.
Any problems, PM me. THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
http://www.fullfatrr.com/forum/topic666.ht...vented#end
2008MY TDV8 Vogue SE, Stornoway/Jet/Piano/ RSE+DVD
2003 Defender 90 TD5 Hard Top Ruggedised
*Gone: Range Rover Vogue TD6, JE Stage 1
*Gone: Range Rover Sport Supercharged 4.2V8
*Gone: Range Rover Vogue Classic 3.9 Auto
*Gone: Land Rover Series 3 SWB
Post #684 17th Jul 2008 2:28pm
Vogue
Come On Cool you can't do such an adventurous task without showing us a pic Laughing
You seem to be doing a fair few alterations, wheels, light guards, pipes, grill, vents Cool Thumbs Up
Post #685 17th Jul 2008 5:17pm
View user's profile Send private message Reply with quote
I also fitted a set of rear light guards tonight so I will get some pictures posted soon. THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #687 17th Jul 2008 10:05pm
Some pictures of the finished result
Front ones and rear ones done now, very easy to fit.
Post #689 18th Jul 2008 1:23pm
shmoogle
United Kingdom 2008 Range Rover Supercharged Autobiography Auto Chawton White
Do you not get mud and crap caught behind them Adam? How does this sit with your mentalist cleaning routine? Very Happy Halfway Down The Stairs,
Is the Stair Where I Sit.
Post #690 21st Jul 2008 4:05pm
That might happen I suppose, but that just gives me an excuse to clean it harder! Very Happy
Actually, since I got this car I've been much less fussy about cleaning it, probably only gets done once a month now and sometimes, I actually think it looks better with some purposeful dirt on it, proves it's no Chelsea Tractor!
Fit for Purpose sums it up. Mind you its nothing like my dad's, his would put a farmer to shame! Its disgusting. Shocked THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #692 22nd Jul 2008 9:11am
ammars27
2003 Range Rover 4.4 V8 Vogue Auto Buckingham Blue
using the templates you do not need to drill any part of the car body work at all, the mounts fit on behind the lights it took me like 2 hours to fit the all front and back but without drilling any of the cars bodywork?
Post #695 22nd Jul 2008 11:46pm
View user's profile Send private message Send e-mail Reply with quote
must be a different front kit to mine. The factory ones are drilled into the front of the side wings, I just saw a set on a car at a dealer up the road from work.
The rears required no drilling at all. THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #704 23rd Jul 2008 3:15pm
ammars27
actually if look at it it looks like it drilled but there is a thin plate fitted to the indicators that hold the front one i only fitted a set last week
Post #705 23rd Jul 2008 4:15pm
The ones I had which are genuine version have a plastic mounting strip underneath the guard by the indicator strip. This has to be mounted by drilling 2 holes in the wing and pushing in two threaded plugs. The light guard itself is then screwed onto the mounting strip using 2 allen head screws supplied. THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #706 23rd Jul 2008 5:31pm
ammars27
ok i guess my ones were differnt but were supplied by main dealers and i did not have to drill the body work, coz if they get bumped it damages the whole wing which is a more disaster then the light!
Post #707 23rd Jul 2008 5:34pm
Might be cos mine is a facelift version and they changed the fittings?? THE INVENTOR OF THE TERM "FULL-FAT RANGE ROVER" :
Post #708 23rd Jul 2008 5:37pm
ammars27
never know?
Post #709 23rd Jul 2008 5:40pm
ken
United Kingdom 2010 Range Rover Supercharged Autobiography Auto Java Black
Guys the thread nut is known as a rivnut and a proper tool is required to fit it properly Adhesive really is not the answer
Post #831 7th Sep 2008 4:17pm
pyramid1235
United Kingdom 2006 Range Rover Td6 Vogue Auto Java Black
I have got the light guards fitted to my FFRR i think they look excellent and they make no difference to the cleaning! Very Happy
Post #4850 10th Apr 2009 12:37pm
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2012 Martin Lewis
