New Front Disks and Pads Fitted. | |
I'm feeling rather pleased with myself, for fitting a new set of front disks and pads and adjusting the handbrake today. The only slight issue I ran into was that one of the brake pad pins refused to move until I sprayed it with WD40 and left it to soak for a few minutes.
I was surprised that the front pads were only 50% worn, but as the disks were below the minimum thickness I decided to finish the job rather than put it back together. (minimum 27mm, mine were 25mm)
Adjusting the handbrake was simple enough when I finally located the adjuster, I was expecting it to be nearer the access hole, but its set quite far back.
Apologies for the poor photo
Gone - Range Rover Supercharged 2006
