Home > Technical > Rear passenger lighter socket
VaguelyVogue
United Kingdom 2006 Range Rover Td6 Vogue Auto Buckingham Blue
I can't seem to find a specific fuse in the owners handbook for the rear passenger lighter socket (at the rear of the middle glove box) - but it's stopped working - do I need to take the glove box apart to dig the wires out ?
Post #74494 2nd Aug 2011 11:53am
View user's profile Send private message Reply with quote
England 2005 Range Rover Td6 HSE Auto Cairns Blue
is it not in the glove box fuse array..
Post #74501 2nd Aug 2011 12:56pm
VaguelyVogue
Not that I can find (the only one that mentioned a lighter socket had an intact fuse) !
However, diagnostics may not be helped by my very poor description - I meant the central cubby box not glove box - so the lighter socket facing the rear seats next to the rear passenger central air vent !
Post #74504 2nd Aug 2011 1:40pm
dan_uk_1984
I believe the lighter sockets are both fed from the same fuse, they are not designed to be used for anything other than the cigarette lighter. If your front socket is working but rear not, then perhaps someone plugged something other than the lighter into it and it/the wiring is damaged?
The accessory sockets in the boot and inside the cubby box are fed from a 40A maxi fuse in the rear right hand fuse box.
Post #74512 2nd Aug 2011 3:11pm
mzplcg
Location: Warwickshire. England. The Commonwealth. (NOT the EU)
United Kingdom 2007 Range Rover TDV8 Vogue SE Auto Stornoway Grey
They're on a pair of 20 amp regular fuses on my 2007 VSE. main one and one of the rears is on one fuse and the on iside the cubby plus the other in the back of the console is on the other. Boot socket is on its own fuse. Success is the ability to go from one failure to another with no loss of enthusiasm.
Winston Churchill.
Post #74530 2nd Aug 2011 6:18pm
Mikeyjd
Wales 2003 Range Rover Td6 SE Auto Zambezi Silver
May be a daft question. Have you tried the lighter from the front in the rear socket? Sometimes lighter itself plug actually fails. Td6 SE
Previous LR- Disco 300TDi Auto
Post #74554 2nd Aug 2011 8:59pm
VaguelyVogue
Ah yes - children with a DVD player on the lighter sockets Whistle I'll check the actual DVD current draw, but I would expect it to be a lot less than the actual lighter !
The one inside the cubby appears to be off too - so I'll have a dig around the rear fuse box too this evening - thanks.
Post #74578 3rd Aug 2011 8:39am
dan_uk_1984
Perhaps its prolonged current they dont like?
Post #74579 3rd Aug 2011 8:41am
VaguelyVogue
Sadly all of the front & rear fuses are fine - so a cubby box stripdown is scheduled for this weekend ...
Post #74725 4th Aug 2011 11:42am
Powered by phpBB © 2001 phpBB Group. SEO by phpBB SEO
Site Copyright © 2006-2012 Martin Lewis
