![]() | Home > General > FFFR Creaking and Groaning |
| alanm_3 Member Since: 19 Feb 2011 Location: Glasgow Posts: 1304
Worn suspension bush? 2008 TDV8 Vogue SE in Java black |
| 47p2 Member Since: 05 Oct 2010 Location: Glasgow Posts: 2996
Your wallet is jammed between the bodywork and the exhaust |
| dan_uk_1984 Member Since: 12 Nov 2008 Location: Bude, Cornwall Posts: 3758
As above, rear suspension bush. The rubber creaks when it dries out - dealers are renowned for spraying with WD40 to "cure" the symptoms for a few weeks. Replacement is the only permanant cure, but you can probably put it off till next spring as the noise will go away in the wetter/cooler months. |
| JOKER Member Since: 11 Sep 2008 Location: Here Posts: 7729
Cheers guys |
