![]() | Home > Maintenance & Modifications > Where did these come from? |
| trafpol Member Since: 15 Jun 2011 Location: Surrey Posts: 129
They look like the shim springs off the caliper 2006 MY Autobiography. With 'toys'
| Mr Tee Member Since: 13 Dec 2010 Location: Tayside Posts: 120
Aha, father in law recently replaced the pads, what do they do? |
They stop the pads from shifting about under braking - sometimes causing squeking - there are holes on the side of the pads where they go in, push the in with pliers and twist to lock them in place. |
| 47p2 Member Since: 05 Oct 2010 Location: Glasgow Posts: 3010
They are the pins and springs that hold the handbrake shoes in place. Number 11 and 12 in the picture below.
wow - you see Im always impressed at answers on here and the knowledge people have and the way the answer is clearly presented. Good post. |
| stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 393
guess the father in law is in the chair for the beer for a week or two then.. |
The scraping noise is caused by the brake shoes rubbing against the disc as the pins are not there to hold the shoes against the backplate. You need to have them fitted as soon as possible before further damage and expense occurs.
Right, sounds as though they could have fallen out due to corrosion as there would be no reason to go near these for pad replacement? Do you nee to take the disc off to access the backplate? |
If he only changed the pads it will not be his fault, the handbrake shoes have to be accessed by removing the discs.
Thanks , going in for MOT on Monday, hopefully get the use of their 4 poster to get this fixed! |
Fingers crossed, we'll get the use of a lift pre-mot, if not, car off road! |
