Home > Maintenance & Mods (L322) > Acoustic Cover removal TD6 - cant get mine off.. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
would the oil filler cap be stopping the removal.. |
24th Feb 2012 7:07pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Mine just sits on top of engine, no fixings |
24th Feb 2012 7:54pm |
DaveAngel Member Since: 15 Aug 2011 Location: Cowplain, UK Posts: 205 |
Front piece first (there is an additional screw hidden down to the left of the front panel). The top left cover has capsulated screws. You will need to remove the filler cap, i would put it straight back on once the cowling is removed to make sure nothing falls into the engine. __________________
1st Mar 2012 11:04pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1490 |
Is the tractor anything like the V8 where you have to remove the air intake box from in front of the windscreen scuttle to get to the two final nuts?
2nd Mar 2012 9:28am |
