Home > Maintenance & Mods (L322) > TD6 oil change durationx
ahebron
New Zealand
Hello whats the consensus on durations between oil changes on the TD6 engined FFRR. I like to change filters every oil change
On my old 300TDi Disco I used to change the dino oil and filter every 5000km which meant I was doing up to 5 changes a year.
Or do you wait till the car tells you to do a change?
Thanks
Adrian
Post #109596 27th Feb 2012 11:27am
edward.barry
Ireland 2005 Range Rover Vogue Td6 Buckingham Blue
I read somewhere that the service interval was 20,000 but at some stage this had been shortened. Personally I have been changing the oil every 5,000-6,000 miles for peace of mind. With the suspension raised, its an easy task (except for the cost of fully syn oil of course) I know Land Rover says to go beyond that under normal driving conditions, but I have never waited so long to change the oil in any car.
Again, oil filters for this engine are relatively cheap and easy to access, which means the task of changing the oil alone shouldn't take any more than 30 minutes and well worth the effort I think. Depending on the model, there is a proceedure for resetting the service interval on the dash.
Resetting the Oil Service or Service Interval Message.
Ignition key must be “off”.
• Press and hold the trip odometer button in the instrument cluster (left button), and turn the ignition key to the first position (KLR).
• Keep the button pressed for approximately 5 seconds until one of the following words appear in the display: “OIL SERVICE, or “INSPECTION”, with “reset”.
• Release the reset button and press and hold it again until “reset” begins to flash.
• While the display is flashing, press the left button briefly to reset the service interval.
After the display has shown the new interval, the following will appear: “END SIA
Regards
Ed 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
Current fleet
2005 RR td6
1997 300 Discovery
2005 Subaru Legacy Outback (the wife's)
1981 2.5 Opel Commodore
Post #109872 28th Feb 2012 10:19am
It very much depends on the mileage you do...We service customers cars on a 12 monthly basis except for those that do high mileages and then its changed as per the dash reading which is usually somewhere between 12 and 18K depending on the driving style...
Craig Thumbs Up
Post #109875 28th Feb 2012 10:43am
m90got
United Kingdom 2003 Range Rover HSE Td6 Alveston Red
Does the ffrr adjust its service intervals to match the way the car is driven ie motorway milage against pottering arround town Current Stable:
Range Rover 2003 TD6 HSE Alveston Red, Sand Leather
Ford Focus C-Max silver 2003
V/W transporter Blue 1995
Yamaha XJR1300 Yellow 2002
Kawasaki ZX7R Green 1998
Honda CBR 600 Black 1998
Yamaha RD125LC Mk1 Red 1986
Yamaha RD125LC Mk1 Blue 1986
Post #109888 28th Feb 2012 12:11pm
Johnte
Regards
Ed
Been trying for the last 1/2 hr to do this - must be doing something wrong Embarassed
Does it work on a 2006MY ?
Post #109933 28th Feb 2012 3:51pm
edward.barry
Sorry Johnte, as I understand it, up to and including the 2005 model I'm afraid. Works on my 2005 Vogue. Regards Ed 0-60 takes 5 and a half seconds...and about 17 gallons of fuel....
Current fleet
2005 RR td6
1997 300 Discovery
Post #109935 28th Feb 2012 3:54pm
