Home > Technical (L322) > 3.6 TDV8 Engine Noise
PaulTDV8
Hi, I have started to have a stange 'chirping' / high pitched 'tweating' sound from the engine when it is under load between 2000 - 3000rpm. It isn't always there and you cannot make it make the noise when at a standstill and revving the engine. There is no loss of power and the car is still pulling smoothly but the noise is annoying.
Dealer first thought it was a split hose but without taking grill off and starting to look couldn't say for certain. Then I mentioned the TDV8 exhaust manifold problems on the RR sport and it was suddenly yes thats what it is... Don't want to book it in and pay dealer rates for them to start to look for the problem! It was bad enough when under warranty but if I'm paying for it I would rather find out on here. In my experience unless the diagnostics can tell the garage what is wrong then the success rate of finding and solving problems isnt great.
Thanks in advance for any advice.
Post #110498 2nd Mar 2012 2:15pm
verydisco
Time to find a good local indy Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #110501 2nd Mar 2012 2:24pm
PaulTDV8
An Indy might charge less but I was really looking to see if anyone else has had experience of this type of noise....
Post #110969 5th Mar 2012 11:57am
goncalo
Portugal 2007 Range Rover Vogue TDV8 Java Black
My car has the same problem they LR garage says it has the manifold exhaust studs broken in one side and makes the noise... and 2.400€ to fix it Shocked
There is any problem to keep car going with this problem or is better to fix as soon as posible, i thought it was some distribution belt or othe belt that when you need more power makes that noise while is more fast... but no!
This is a common problem?
2.400€ to fix some studs is crazy!!!
Thanks Ex-FULLFATTY now downgraded
L494 RRS P400e Dynamic Narvy Black
-------------------------------------- gone
6 | FF-RR 2007 TDV8 Vogue JAVA BLACK
5 | FF-RR 2003 TD6 Vogue Bonatti grey
4 | Ex-RR 2000 P38 automatic
3 | Ex-RR 1994 300tdi classic
2 | Ex-RR 1993 200tdi
1 | Ex-RR 1991 turboD VM engine
Post #457154 13th Nov 2017 6:23pm
chugga90
Mine did this when I had it, it was the drivers side right hand one which had warped and snapped most of the studs.
Parts, Labour and vat was around £2,000.00.
Probably better sooner than later as possibly less snapped studs earlier in the issue than leaving it too long?
Post #457160 13th Nov 2017 7:03pm
Zeb
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
For future reference...at what mileage is this possibly going to happen?
Post #457202 13th Nov 2017 11:43pm
chugga90
Mine was around 138,000 miles.
Post #457220 14th Nov 2017 8:26am
goncalo
Mine has 168.000km.
Anyone knows why this happens? Is a common problem in the TDV8? Rolling Eyes Ex-FULLFATTY now downgraded
Post #457228 14th Nov 2017 10:13am
rar110
My 2007 MY08 Is running great at 267000km. And I have cained it on soft sand. But has been serviced every 10k km. I’m loving it ATM. ______________________________
Post #457242 14th Nov 2017 12:58pm
goncalo
I only think this is very strange... what can make this happen? Ex-FULLFATTY now downgraded
Post #457245 14th Nov 2017 1:08pm
rar110
Sorry mate I’ve no idea. As far as I know it’s uncommon. A bit of bad luck I’d say. ______________________________
Post #457246 14th Nov 2017 1:23pm
goncalo
At least is not a common problem!
The car was in LR to fix the coolant leak problem, maybe it was them... Rolling Eyes
And now after 8000km after they fix, 2 days ago i got the message - COOLANT LEVEL again!!!
... and is normal the level? Rolling Eyes So strange!!! Ex-FULLFATTY now downgraded
Post #457248 14th Nov 2017 1:28pm
rar110
Gon, possibly take it back to see what LR say. My Indy put a stop leak sealant through my motor to stop a leak. It seems to have worked.
P ______________________________
Post #457254 14th Nov 2017 2:16pm
goncalo
Rar,
I don´t have a leak! the level is the same as leval from last 4 months and 8.000km... was just the message 2 days ago, today is normal Rolling Eyes Ex-FULLFATTY now downgraded
Post #457269 14th Nov 2017 5:10pm
finchi
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
I guess the manifold stud fix is expensive as it requires engine removal? Mine as had head gaskets replaced. which required engine removal. In many vehicles this is possible in stiu.
Post #457274 14th Nov 2017 5:49pm
