Home > Maintenance & Mods (L322) > Upper tailgate slam..
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Does anyone else's upper tailgate sound like a tin can when u shut it?! Mine shuts quite loudly,is there anything I can add to soften the blow when I shut it? It sounds cheap and nasty at the mo
Post #111063 5th Mar 2012 8:46pm
like shutting the door on a tractor....i know its a big clunk but its normal... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
workshop manual downloads are in our wiki
Post #111065 5th Mar 2012 8:51pm
Stephen.125
2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
There was another thread on here where someone with a >2010 said theirs was softer. I guess there may be a chance you could put the 2010struts on?
Post #111085 5th Mar 2012 10:12pm
As Stan said, its a standard no cost option ticked for every one that left the factory Very Happy
Newer dampers may help but i think ultimately the only way to go is some thick rubber feet/wedges on the lid to dull the impact... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #111091 5th Mar 2012 10:25pm
enumbers
Ireland 2004 Range Rover HSE Td6 Adriatic Blue
new dampers will make a big difference mine was closing like a barn door till I changed them.
Post #111100 5th Mar 2012 11:07pm
just wondering if after years of slamming the struts have got worn.....
dampers from where mr enumbers... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #111101 5th Mar 2012 11:11pm
I think the struts and dampers are the same thing as they do perform both functions Very Happy FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #111102 5th Mar 2012 11:14pm
Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #111131 6th Mar 2012 9:29am
Something else to check, are both of the catches working on the lower tailgate? If only one works (as we are finding more often as the cars get older) The top tailgate gets much harder to close (and much much LOUDER!!!)
Close your bottom tailgate as normal, then grab the top corner one side at a time and see if you can move it forward and back. It should be quite obvious if its not catching. If it does not catch on one side, open and either push or pull (i cannot remember which) the little plastic lever on top of the catch (looks alittle like a plastic shield) then re-close the lower tailgate and it should work. It basically means the catch does not latch correctly or automatically any longer and moving the plastic lever to either the forward or rearward position lets the catch work manually...
Then close your top tailgate and you should find its a hundred times nicer to close (if the lower latches are at fault)
Craig Thumbs Up
Post #111138 6th Mar 2012 9:45am
Lolo
Thanks lads for the suggestions, I'll check it out.. See what I can come up with, maybe add some padding on certain areas if I can't find anything wrong.
Post #111179 6th Mar 2012 12:55pm
Flashman
I will check the dampers too, when I close mine it sounds terrible and cheap. Waiting for the lower tailgate mod parts from Dan will do both together. Tom
Current Drive
Previous Drives
Post #111238 6th Mar 2012 5:56pm
