Home > Maintenance & Mods (L322) > Front washer nozzle
duka
2010 Range Rover Autobiography 4.4 V8 Alaska White
Front washer nozzle
I've stripped down one of my front washer nozzles (heated type) due to nothing coming out (air or water). When blowing an air line through the two separate componenets, both have air out the 'other' side fine, but when re-assembled nowt!
any clues?
Post #112245 10th Mar 2012 1:09pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Is it possible that the hoses leading to the nozzles are kinked or blocked in any way? No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #112249 10th Mar 2012 1:34pm
I had this recently on one of my nozzles, not worth playing about with, £6.50 from Duckworths. Smile
Don't throw the old one away, you need to remove the clip that holds the electrical connector to the bonnet metalwork. LR appear to be too stingy to include it with the new nozzle assembly.
Post #112270 10th Mar 2012 5:54pm
duka
water comes through the feed hose ok, nozzle is off the car....new nozzle it is then
cheers
Post #112375 11th Mar 2012 10:53am
