![]() | Home > Technical (L322) > Please help me diagnose the RR from the datalog file ... |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1487 ![]() ![]() |
Tearing my hair out with this one. Since replacing the MAF, I just cant get it to stop coming up with the error of both banks running rich. I bought an after market new MAF, I've tested for intake leaks and I've cleaned the throttle butterfly area as much as I can ... I'm going to pull the spark plugs tomorrow, but I'm at the stage of going out and buying a genuine just to see if its the MAF thats the problem.
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 ![]() |
Managed to download this now from a different location & browser. At what point during the run is the error generated? |
It doesn't quite get to the point of the engine light coming on on the run I did, but if you look at column C ... thats my long term fuel trim - the base value of adjustment the car does to try and keep the general fuel ratio correct.
I would suggest to run the car with injector cleaner mixed in the fuel for a bit. I had similar issues with one bank being too rich and knowing (part of) the history of this car (sitting still for two years) it may be gum deposits in the fuel system that cause the injectors to give some extra fuel. Although with me it was one bank (1) and a long term fuel trim of 2.54% as opposed to 0.8% on the other bank.
I'll not rule it out, but i will say that i seem to ge tthe error on both lpg and petrol ... which makes me think that its less likely to be the injectors. V8 or else ... |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
I'm going to assume that "sensor 2" is the post-cat O2 sensor, like mine.
Thanks for taking the time to look at it. I'll have a look at the downstream sensor data, although i had glanced at it as I had been under the impression that trim was set by U/S only and D/S was just for the system to check the cats were working.
Thats my logic too and is my gut feeling. I,m picking up an LR MAF tomorrow from the dealer and will how that goes. When I get it, i'm going to put all 3 sensors into the engine 1 after another and compare their readings in terms of air flow and temp. ( i know the original will have no airflow, but I have a suspicion the temp readings may vary. V8 or else ... |
U/S D/S:
Jim,
Good news.
I understand what youre saying ... but the software lists the O2 readings as
Yay new MAF!
my generic reader can read up to 4 O2 sensors on each bank.
Bank 1 is the LEFT (odd cylinder) bank Bank 2 is the RIGHT (even cylinder) bank sensor 1 is upstream of cat sensor 2 is downstream of cat Left and Right from the driver's seat. Even for you guys who steer from the wrong side of the car. ![]() 2000 NAS HSE 2005 NAS HSE |
