Home > Technical (L322) > Urgent help required - alarm going off solid tone
ric355
I connected my OBDII reader to the car this evening and before it had even been connected up properly (plug in dash but other end not connected to reader) I got a loud solid tone from the alarm module, air suspension fault, no interior lights, and central locking all failed. I get repeated solid tone all the time unless I have the key in the ignition in position 1 and have the RAC diagnostic cable connected. Plugging the usb end into my lappy to get RAC up and running causes it to go off with a solid tone again.
HELP! It's getting late and my neighbours are going to be really Censored off with me.
Oddly enough I can still start the car with the key and drive it.
Power steering has gone all heavy, and the interior lights are flashing a bit.
Feels like some sort of short circuit?
Post #117247 11th Apr 2012 9:39pm
dis-connect the battery....remember to do the steering wheel sequence when re-connecting... ... - .- -.
Post #117248 11th Apr 2012 9:44pm
daveo
was the lead connected to your laptop, what i am looking at is any type of power short, now this may sound strange, have you closed the obd flap as some of them have a small jumper in the flap.. just a thought Question V8 facelift Range Rover Autobiography 22" wheels.
Post #117250 11th Apr 2012 9:46pm
ric355
Already tried it. The alarm goes from solid tone to beeping. Nothing works still. I think the BCU may have gone pop.
Post #117251 11th Apr 2012 9:46pm
daveo
sorry just read your post again, you did say it was not connected, close the flap and disconnect the battery give it 5 mins and reconnect, make sure your keys are NOT in the ignition when you reconnect. V8 facelift Range Rover Autobiography 22" wheels.
Post #117252 11th Apr 2012 9:48pm
ric355
Tried closing the flap, yes.
Just reading RAVE. It says the alarm has a constant tone but doesn't say when it is triggered. It also says the BCU cancels the alarm when it receives an appropriate signal, which is presumably why it stops when I put the key in position 1, but that's the only way I can stop it and I can't leave it like that all night.
Post #117253 11th Apr 2012 9:49pm
ric355
As soon as I close the flap, the alarm goes off again! Have battery disconnected at the moment, but the backup battery on the sounder is keeping the neighbours nice and angry.
Post #117259 11th Apr 2012 10:04pm
ric355
Sounder has stopped beeping for the time being. Going to have to leave it like that now overnight. It's all unlocked though - daren't touch it in case I set it off again.
What a mess. Will have to try reconnecting the battery tomorrow.
Post #117260 11th Apr 2012 10:11pm
I think you've popped the fuse for the BCU... Its in the glovebox fusebox... Have popped the fuse twice on customers cars whilst converting and they come up with the identical faults you are describing... I cannot remember which fuse number it is and im not sure off the top of my head what the fuse symbol they use either...Sorry to be vague! Just visually check them quickly, im quite confident you'll find one gone...
Craig Thumbs Up
Post #117277 12th Apr 2012 12:23am
ric355
Many thanks for that Craig. I'm popping home at lunchtime to take another look, so will check that first. Is it a standard automotive fuse? Got plenty "in stock" if it is.
Post #117307 12th Apr 2012 9:37am
Yes, a 10amp if memory serves me correctly, start on the bottom row as i think i checked almost all of them before i found the blown one...
Craig Thumbs Up
Post #117308 12th Apr 2012 11:29am
I got this when I pulled Fuse 8 (radio) a while back, alarm went away when i put it back in though. Don't think I had the key in either. .
Post #117312 12th Apr 2012 12:14pm
ric355
Many thanks to Craig - Fuse 15 blown (5A). Only took two attempts to find the right one!
Replaced and now all fine again.
Phew!
Post #117313 12th Apr 2012 12:34pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Excellent result.. Fare play to Craig Thumbs Up
Post #117317 12th Apr 2012 12:41pm
nice prognosis craig.... Thumbs Up ... - .- -.
Post #117318 12th Apr 2012 12:50pm
