Home > Off Topic - Other Cars > Jaguar XF
Jaguar XF
Good idea Bellini …. you as well Martin ... Thumbs Up
Any member got one, the wife's has this problem with her drivers side window whenever she opens it , the window keeps bouncing up and down about 3 / 4 times before it will close ====================================
Post #118425 20th Apr 2012 1:37pm
Have you tried a reset on it?
Post #118430 20th Apr 2012 2:01pm
So how do i do that John ...
Phoned Taggarts they told me a could be looking at some sort of new motor for it which could cost £300 to fit ….. Shocked ====================================
Post #118434 20th Apr 2012 2:04pm
DMRR
Amusingly that is the same issue that my 2010 RR had .... it's a dealer fix. They need to sort the window ECUs Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #118435 20th Apr 2012 2:04pm
Window fully down, hold switch for 5 seconds or until you hear a click (whichever is soonest) window fully up and keep holding button for 5 seconds or until you hear a click (whichever is soonest)...
Might work, might not but worth a try Mick
Post #118440 20th Apr 2012 2:15pm
Pfazz
2019 Range Rover Autobiography SDV8 Loire Blue
Re: Jaguar XF
I had the same prob on my 2008 xf, stratstone replaced both front controllers under warranty, you may be able to persuade them to do the same even if out of warranty if it has been the subject of a technical service bulletin. You can search here for info. http://www.mycarstats.com/reports/jaguar/xf/tsbs.aspx
Hope this helps. Agueroooooooooo. 93-20
I swear you will never see anything like this ever again....watch it..drink it in.
Post #118441 20th Apr 2012 2:33pm
Pfazz
Re: Jaguar XF
Home on the Range Agueroooooooooo. 93-20
Post #118460 20th Apr 2012 5:03pm
mzplcg
Mick, it needs a software update on the window ecu. Wifey's was the same from new. It's just too sensitive on the obstruction detection.
Dom.
Post #118487 20th Apr 2012 7:09pm
mzplcg
Double post Evil or Very Mad
Post #118488 20th Apr 2012 7:09pm
Cheers Dom …. Thumbs Up ====================================
Post #118499 20th Apr 2012 8:15pm
