![]() | Home > Maintenance & Mods (L322) > Compressor |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
My air compressor has become very lazy so much it would take an age to reach offroading height if at all. I got hold of an old compressor off the bay and with another one from swast (Adam) made one good one. I stripped them both down and the main thing was pistonring being worn. The cyclinder had a nice groove at the top where the piston had worn the ring down and was contacting the cyclinder at the top. I used a bit of wet and dry and roughed up the piston ring then put a nice coating of vacume grease all over the ring (yes dirty mInds can add an innuendo here). Also did the same with the valve in the cyclinder head. Rebuilt and tried in the car!
I don't but can take some of the bits I have left? Anything specific? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222
Hi Rob
| Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1530
Hey Rob,
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Guys, a quick test for all of you... If your car struggles to achieve off road height? When it gets quite high up on the airbags, stand with your bum on the front wheelarch and lift the side of the car a little and listen for air leaks (dont go too mad as its just an aluminium wing) Then repeat on the other side...
Once it's out of the car it took about 10mins to strip to the piston. Mine was a spare so was already out of the turtle shell, but that's easy to get into. Remove the bracket with mounts on. 10mm socket and think it was 8mm to undo the pressure valve. Once thats off, remove the hoses there just push lock fittings. Then use a a trorx to undo the head bolt and a 10mm open ender and pull the head off. Then you can clean up and inspect. I cleaned up the air cleaner side the big black tube. That's sprung so be careful when undoing the last bolt. Not powerful but will make you jump and you could loose some of the bits if unprapared.
Craig
Thanks a lot, Rob!
