Home > Technical (L322) > RR 2003 v8 woes - advice and help please!! |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
hi 1,3 and 4 can be related, if you are talking the PCV breather hoses at the back of the then that is a common fault but can have drastic effects if they block, they also can leak oil, and when not breathing correctly return bad mpg..
11th May 2012 11:18pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
The M62 petrol rocker cover gaskets are prone to leak. The tend to go near the back and will leak onto the exhaust. Do you have a warranty?
11th May 2012 11:21pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
The oil return banjo connection is down on the oil sump, well below the exhaust system, and impossible to leak onto exhaust parts. Unless you turned gravity off.
15th May 2012 3:35pm |
Rykard Member Since: 16 Apr 2012 Location: Leicester Posts: 74 |
where are you? I have a good garage near me who is pretty good with engines.. cheers
15th May 2012 4:23pm |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Burning oil smell at the lights sounds like rocker cover gaskets.
15th May 2012 4:30pm |
15th May 2012 4:41pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Hi
15th May 2012 6:29pm |
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 528 |
Apologies for the slight hijack - but is there a similar issue/cause with the JLR engine? Mine has a whistle, has had it for a while, it's noticeable when you're moving, never changes pitch or volume, but stops when the vehicle is stationary - and restarts as soon as you move off! I did think it sounds a bit like an induction whistle but I don't know where to look? |
15th May 2012 6:48pm |
Scuttle loose below the windscreen try clicking it back down.... |
15th May 2012 6:51pm |
rmackinnon Member Since: 14 Mar 2012 Location: Mansfield, UK Posts: 85 |
Hi Everyone
15th May 2012 8:57pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 911 |
A possibility for item 2 in your original list is a faulty fluid temperature sensor
15th May 2012 10:04pm |
Hamster97 Member Since: 04 Apr 2015 Location: Derby Posts: 2 |
I love digging old threads up but was the oil leak ever cured and what was it. I've got exactly the same issues with my 04 vogue, pcv and hoses were changed under warranty (there was an assumption that the pcv was causing the smoke which was later discovered to be oil leaking onto the exhaust and burning off). As the dealers garage was in Leicester and I am in Derby, I opted not to return the car for further diagnosis.
26th Oct 2015 10:16am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2025 |
you could do no wrong, by getting some latex gloves, and some clean tissue, and wiping round the rocker gaskets both sides, with engine cold. run it for a journey, and wipe again to see the oil etc. these rocker gaskets are made of rubber, and they harden. they can also crack. then the oil is free to run out. its true the PCV system is also leak friendly. but if you are prepoared to get your wrists a bit dirty, you could find the possible cause, and then get them changed. -they also leak around the inside rocker gasket seal, and let oil into the spark plug wells. (there is an outer and inner gasket) so, if you can open the 10mm (hidden) nuts that hold on the rocker cover inspection covers, (black grooved plastic covers) you might well see oil in those plug wells. with say a couple of cotton buds on a toothbrush stick etc. this would mean rocker gaskets, and you might then want to change the plugs as they are completely exposed to be changed easily with rocker cover off.
26th Oct 2015 12:04pm |
