Home > Technical (L322) > Door lock broke, cant open door
Stuart's the man
Hi guys,
I have a broke front passenger door lock, or cable of and can't get the door to open from inside or outside. I know this is a common problem, but have done a search and can't find anything about it. Any help pointing me in the right direction would be greatly appreciated
Post #122272 17th May 2012 7:10am
these might help,
http://www.fullfatrr.com/forum/topic8316.html?highlight=door+lock
http://www.fullfatrr.com/forum/topic3712.html?highlight=door+lock
http://www.fullfatrr.com/forum/topic5478.html?highlight=door+lock ... - .- -.
Post #122288 17th May 2012 8:29am
Stuart's the man
Thanks for that,3rd one down helped. Managed to get panel off enough without any damage, then smashed door lock off.new lock fitted and working. The way I done it was undo 4 screws holding panel on, remove B post trim along with front door seal,remove black window trim from door panel and then a gentle lever to remove it from top clips. You are then in to the lock mechanism, all in an hours work and £81 for new lock. I took pictures of job in case anyone needs help
Thanks for the help Stan
Post #122601 18th May 2012 9:29pm
you're welcome stuart, glad its sorted.. Thumbs Up ... - .- -.
Post #122605 18th May 2012 9:40pm
